stopcrazypp
Well, I'm not the type of person that trust appeals to authority with no math, so I choose to trust the author who said he did the math rather than the two choices you offered (which is a false dilemma).The problem is temperature differential per volume per second. Since, you are not an expert on it, you can either take my word for it, or become an expert. You might get that kind of cooling by bubbling the air through liquid nitrogen, but otherwise, I don't see how to do it.
As to the small fan, those fans you found assume no back pressure, not trying to run sealed air volumes past vast areas of heat exchangers. Nor was I talking about physical size.
And again, you did not address my point about why the radiator in the front of the car can remove the same amount of heat through air (actually more, since it actually has to handle drivetrain/inverter heat) and why suddenly this becomes impossible as soon as it moves inside the pack.
There are equations available that can simulate the author's proposal (which involves blowing air around a cylinder), but I'm a bit lazy to find all the variables and do the math.
Churchill–Bernstein equation - Wikipedia, the free encyclopedia
To be clear, I'm not in favor of an air cooled solution (I prefer liquid and I wrote a long post about the major issues with the author's article), but so far I have not seen any definitive proof that the author's solution is impossible.
