For those that have parked their Model Y's at an airport, how much battery drain per day have you experienced?
I do understand that Sentry Model, the overheating protection and the outside temps mean it will not be the same for everyone.
I would still love to hear everyone's experiences.
I will be picking up my first Tesla (Model Y Performance) a week from today and have to get on a plane just days later.
Thanks.
it's probably worth summarizing stuff after all the back-and-forth...
When the car is asleep, it consumes very little energy. It loses perhaps a few miles of range per day, at most. The
percentage loss is of course dependent on your battery size/model, but it will typically be 1% of SoC every 1-2 days. So while asleep, the car can safely be left for a couple of
months assuming it starts with a 90% SOC.
Unless something is preventing it from doing so, the car will go to sleep by itself after its been parked and locked for a short time. So you just lock the car, walk away, and the car will take care of itself.
Some settings/options stop the car from sleeping. This includes the following:
Sentry Mode This keeps the car awake since it has to monitor its surroundings via the cameras/computer.
Smart Summon Standby This keeps the car awake so that it is more responsive to smart summon requests from the phone app.
Cabin Overheat Protection This wakes the car up to cool down the interior should the car overheat in the sun.
When the car cannot sleep it consumes much more energy. When awake, the computers etc consume about 10-15 miles of range per day, or something like 5% of battery
per day. So if you start at 90% SOC, you will be down to 20% after about two weeks.
The car will always sleep when the battery reaches 20% SOC. Regardless of your settings/options, once the car reaches 20% SOC it will go to sleep to conserve the battery, so that last 20% will only be used up at the (much slower) sleeping rate.
So, here are the general rules I follow:
1.
Always disable Smart Summon Standby. Many people never use this anyway, but if you do be sure to disable this when you leave the car for any length of time. This is important, since you
cannot turn this setting on/off from the phone app. So if you forget before you leave, you are hosed.
2.
Enable Sentry Mode for 1 Week Trips. If you can get the car parked with a decent SOC and your trip is one week or less, leave Sentry Mode on. it's good for peace of mind.
3.
Disable Sentry Mode for Longer Trips. If the trip is longer than 1 week, make sure the car has a decent SOC and disable Sentry Mode so you are not worried about the SOC when you return.
What happens if your short trip gets extended? Simple, just disable Sentry Mode from the app. And
dont check the SOC 10 times a day .. you will wake the car up, making it consume even more energy. Just check it once a day for peace of mind.
Note that the various combinations of settings make very little difference to overall energy consumption. Any combination of settings that stop the car from sleeping will end up consuming energy at the higher "awake" rate (though overheat
will take more energy if its used heavily).
HTH
