Good call, I'd forgotten Gordano!Gordano Services might be a better emergency option than Cribbs or Lysander. Cribbs is in a multi-storey car park, so height restricted, and Lysander is a bit tight if you are towing.
Its a new boat purchase, collection from South Coast...Why not just take it for an out and back of say 50 miles, record the consumption and any confounding factors then use that figure for the trip (with a safety factor!)
I'm between the Midlands and Anglesey a lot, so am familiar with the journey... There may well be merit in sitting on cruise at 55mph on motorways rather than stop start and A Roads.. Given a stop in Flint is likely the extra ten miles or so is neither here nor there, and then Hilton P makes sense too....I think the general view is double consumption but no doubt t varies by load and aero. You might want to check the towing limits as the M3 isn’t as high as some other cars.
You’ve also got the option of Hilton park if needed, it’s just after the M54 turning but leaving the m6 at the first exit after the services adds only a short stretch of an A road to get across to the M54. Something you can play by ear on the day.
Telford to Anglesey won’t be fun though. It’s a longer route on paper but staying on the M6 and then heading across the M53 might be an easier drive, that said, my frustration of the A5 is following people with trailers..
I'm approaching 50 but am still happy with 12-14hr days in car if need be. I've afew fall backs; Father-in-law can do a stint; supercharging stops doubling as nap stops, and I can always sleep at home in the Midlands on way to Anglesey if things have not gone to plan!Flint is a nice stop but further off the A55 than you'd think it'd be.
A major point is that google maps gives the conventional drive time as 6hrs. Add slower towing speeds and recharge/food/bio break stops and you can easily get to fatigue or longer stops - perhaps 8hrs and more. It's a younger man's' game.
I did once do London to Prague with only petrol/toilet stops and in-car snacks but I was 30yrs younger.
Really helpful - thanks...This post might help
Towing experiences with the Model 3
I did my first real towing with my Model 3 last weekend. The plan was to drive from my home in the Leamington Spa area to the gliding club at Bidford (about 30 miles), then collect my glider trailer from there and drive to the Black Mountains Gliding Club In Wales; a destination about 90 miles...teslamotorsclub.com
I was driving average 105km/hr. I knew this trip was going to be a challenge but did not expect it to get that bad... lesson learned. This trailer has absolutely terrible aerodynamics and the extreme cold probably was the nail in the coffin.High, -20 (C?) is an order of magnitude beyond the extreme for the U.K. how fast were you driving? That also makes a huge difference.
No one in the UK is likely to be able to help much with that last question I'm afraid. temperatures that low are few and far between here about as common as Model Y's and the need to tow a snowmobile as it happens.Happy to jump in on this discussion, I just attempted last weekend to tow a double enclosed snowmobile trailer (like a big box). Weight of trailer and snowmobiles 1350kg. I live in southern Ontario Canada and it was extremely cold (-20C). Total distance needed to get to the cottage was 250km. I was expecting to get at least 140km out of a full charge but not even close. Model Y performance was using almost 800KwH/Km. So maximum range I could safely travel was about 70km. My problem started when the last leg of the trip I needed to travel 137km between Superchargers and did not make it. I was forced to drop the trailer at the side of the road, lock it up and call a friend with a pick-up truck to get it and take it the rest of the way to the cottage. I will not be doing any towing with my Model Y in future, just going to rent a truck or swap vehicles for towing. I am curious to know what factor the extreme cold was in losing so much battery??
Ah, yes! There's a reason why the UK & Ireland have their own section of the forum ... not quite comparable conditions here!I live in southern Ontario Canada and it was extremely cold (-20C).
Agreed, the temperature is the big difference here but that aside, towing something that weight with poor aerodynamics is going to be a huge challenge no matter the temperature. Just wanted to share my experience in hopes it will help someone else.The model 3 will be towing 1000kg max, so that helps. Also likely to be a more streamlined load. And at a temperature which is likely to be at least 25 degrees celsius warmer! Overall I would say not comparable.
Yes probably. Most over here would also consider 65mph to be going pretty quickly when towing, even with an ICE regardless of the weather. If you get stuck behind someone towing a caravan here you’ll be lucky to be doing 55mph.
For reference lorries are limited to 56 on the highway and 50 on roads without a central barrier.
Fortunately we do not actually get THAT cold too often. The snowmobile trailer is like towing a sail, terrible for wind resistance.No one in the UK is likely to be able to help much with that last question I'm afraid. temperatures that low are few and far between here about as common as Model Y's and the need to tow a snowmobile as it happens.
not in Scotland ;-)The UK legal limit is 50 mph on single carriageway roads and 60mph on motorways ...
not in Scotland ;-)
I've only just seen these replies from this date onwards, I'm glad I didn't see this before my trip.... For those interested I am about to post a very brief summary..Happy to jump in on this discussion, I just attempted last weekend to tow a double enclosed snowmobile trailer (like a big box). Weight of trailer and snowmobiles 1350kg. I live in southern Ontario Canada and it was extremely cold (-20C). Total distance needed to get to the cottage was 250km. I was expecting to get at least 140km out of a full charge but not even close. Model Y performance was using almost 800KwH/Km. So maximum range I could safely travel was about 70km. My problem started when the last leg of the trip I needed to travel 137km between Superchargers and did not make it. I was forced to drop the trailer at the side of the road, lock it up and call a friend with a pick-up truck to get it and take it the rest of the way to the cottage. I will not be doing any towing with my Model Y in future, just going to rent a truck or swap vehicles for towing. I am curious to know what factor the extreme cold was in losing so much battery??
