I'm sure that will prove to be invaluable information for others contemplating towing trips. Good that it was at low temperatures too. Do you know the combined weight of the boat plus motor plus trailer combination? [Edit: And is the trailer braked?]Right - trip was last Friday, the very short answer is I made it, a short summary below if anyone is interested. I've tried to uploand a couple of photos..
The boat on trailer is quite tall, above the line of the car, but more aero than a slab fronted trailer undoubtably.. Chilly day (by UK standards not Canadian!), the journey down was around 2-degrees C, then with the boat the max I saw was 7 degrees C
First stop was Exeter where fortunately the configuration and quietness of car park enabled an unhitched charge. The short 40 miles to Exeter with boat were average 700wh/m, bang on my number for making the longer stretches.. I charged to I think it was 96% as by then it was so slow...
The M5 to Michaelwood was cruise set at 60mph, which was ideal as hooking to the back of a truck meant a flat 58mph speed. Got to Michaelwood with 7% SoC having averaged around 640wh/m
Essentially that set the template, but a diversion from the M54 Before Telford meant pulling in at 2%, which given the charge was dropping basically at a % a mile was a little close for comfort... Fortunately the chargers were all quiet so I managed to charge all without unhitching which was great, and one of us stayed with car at all times in case it caused an issue, but there were always free ones available. Flint the easiest way was simply to drive the car behind the charger
Got to Anglesey 02.30 having lefy my house at 08.30 the day before, 580 miles covered, 395 of those with boat. Overall average 650wh/m. Essentially a 100 mile range on 100%... Glad it was a one off...
View attachment 761272View attachment 761274
Hopefully others can use the info - there isn't a lot of info online really..I'm sure that will prove to be invaluable information for others contemplating towing trips. Good that it was at low temperatures too. Do you know the combined weight of the boat plus motor plus trailer combination?
Really useful info. Is the trailer braked?Hopefully others can use the info - there isn't a lot of info online really..
I worked out about 950KG. +/-50KG
Boat 500kg, outboard 200kg, trailer 250kg, but thats internet research as opposed to actual weights
Eek! How was the general driving feel? I've driven with a loaded small trailer and you would barely know it was there ... but this looks like a whole different story![Edit - yes braked trailer. Didn't like it as the spring needs adjusting I think, it shunted on the spring a lot. Lifting off down hills it seemed not alot happened, then more not alot happened, then eventually a shunt happened, if that makes sense]
The shunt was more of a clunk if you take away the dramatic word shunt. The actual towing experience was brilliant, heavy car with weight low, 4wd and loads of torque with no gears, it was really easy. As I was nursing range I wasn't using much throttle but it had more than ample power, I was always aware of the tonne or so I was dragging but it wasn't a problem at all.Eek! How was the general driving feel? I've driven with a loaded small trailer and you would barely know it was there ... but this looks like a whole different story!
should have put the outboard in the boot, then it'd have been lighter to tow
wonder if the trailer wasn't braked, would you get better efficiency through improved regen?
I wonder if it's worth combining these experiences in a sticky thread for towing?@pdk42 did another thread of towing his glider across Northern Europe. I think I dropped some w/mile numbers in there too for towing a 250kg dingy.
I'm on mobile just now and couldn't immediately find the thread - will try to remember to drop it in later. I think it's good to link up reference material if we can as it helps answer people's questions.
I did think a sticky or wiki with w/mile experiences with different configurations would be handy for people. Towing, bikes, roof boxes etc.I wonder if it's worth combining these experiences in a sticky thread for towing.
Unbraked is fine untill you need to stop in a hurry or on a corner. Then your 950kg boat would try and overtake you, which is a) embarrassing and b) quite dangerous.I wonder about the trailer too, I have to say my preference would be unbraked....
Anything with a MAM over 750kg has to be braked, so… ?Unbraked is fine untill you need to stop in a hurry or on a corner. Then your 950kg boat would try and overtake you, which is a) embarrassing and b) quite dangerous.
The impact is more noticeable on an EV due to the relative efficiencies. The % range lost on an ICE is less noticeable as the % of fuel burnt that goes towards locomotion is far lower than the % used for locomotion in an EV. With an M3, throw in the quite slippery body shape, and the efficiency losses are highly noticeable. A more aerodynamic trailer would make a huge difference, as that boat is one big airbrake.What level of regen did you use?
I wonder if in this case, coasting rather than regen would have given more range, and reduced the brake shunt.
Another thought: sitting with the trucks would probably have given you some aerodynamic benefit, too.
A further thought, if the tow car had been an Audi AWD hatchback ICE, would the mpg have fallen by half? In other words, does towing with a Tesla have the same impact on range as with an ICE?
Anyway, very well done.
You need to be dangerously close to a truck to get any worthwhile improvement. There's a Mythbusters episode about it and some US transport research kicking about.Another thought: sitting with the trucks would probably have given you some aerodynamic benefit, too.
follow distance 1, or even closer?You need to be dangerously close to a truck to get any worthwhile improvement. There's a Mythbusters episode about it and some US transport research kicking about.
