My 2 cents would be to always do a range charge prior to leaving home. You never know what congestion there might be at Folsom, so having less to charge would be an advantage. Assuming you have the Folsom SC to yourself, I'd again do a range charge. Not that I think a standard charge wouldn't be sufficient to safely get to Incline. No need to stop in Auburn. I just believe that, unlike the NYT moron, you should always charge to the max practical. When you used to drive an ICE I'm betting you didn't figure how much gas you needed to your destination and fill up only what was needed. You filled it up, correct?After reading the excellent post on road trips by ChadS, I am starting to think I've been too optimistic about my charging plans. I still need to work through the math a bit more, but originally I thought
1. Belmont to Folsom, 130 miles, relatively little elevation change. Start with a range mode charge (208 miles on 60kWh battery) and no worries about speed (keep it around 70) or heat. Use the supercharger for an hour while eating lunch (and hope there's no line for the SC).
2. Folsom to Incline village, 110 miles but ~2600 meters total elevation gain and temps drop to around freezing. Start with a range charge and drive conservatively (60-65) but keep heat on (wife and kids in car).
Perhaps that's too optimistic?
If I play it safe I would stop in Auburn at Clipper Creek for their 80A charger, but unfortunately it's only 25 miles away from Folsom and not really that much higher elevation-wise, maybe 400 meters. I'd also have to convince the wife and kids that we need a 1 hour bathroom break only half an hour after lunch in Folsom. Maybe I won't need a full hour at Auburn? I'll have to work on the math but maybe someone with more experience will know off the bat:
1. Should I do a range charge or standard charge at the supercharger in Folsom?
2. How long should I charge (if at all) in Auburn? Back to full standard, full range, or just a set amount of time or miles?
There's not much in the way of high speed charging between Auburn and Incline Village, and I'm not really interested in hanging out at an RV park in the cold.
thanks
Coming home, I'd stop at Folsom and do a standard charge. It's free, remember? And you could drive at any speed you wanted.
I just reread your OP and realize you are of the new 60KW crowd. Consequently, I'm not so sure about what range you can expect. Perhaps someone could shed some light on that.
