Anyone familar or try the Spaccer suspension system?
They seem pretty expensive for the amount of lift they offer.
Alternatives are larger springs from Eibach or a lift kit from Mountain Pass Performance, Delta 4x4, T-Sportline and others.
Just search for Model Y lift kit and you will get lots of results.
Installation is the same for all, you have to remove the front struts and rear springs.
Except installation is not the same: you do not have to remove the struts or springs for SPACCERS because that have a slot, they are not a complete ring, so you can slip them in or out easily. And you can add 0.5" of lift at a time, up to 2". The other competitors require disassembly, and are all in the 1.7" range, so if you only wanted a milder lift there is nothing.
