Anyone had FWD phantom obstacle fixed by SC?
Discussion in 'Model X' started by Krazaak, Jul 25, 2018.
  1. Krazaak
    Krazaak Member
    Charlotte, NC
    My driver's side FWD gets a red bar, phantom obstacle detected if it sits in the sun for more than 5-10 minutes. The SC is claiming that it's a design limitation and the doors just won't operate above a certain surface temperature.
    Obviously, that's simply not true or thousands of people would be having the same issue. Had anyone had chronic FWD problems that has actually had this fixed? It happens to me multiple times a a week, sometimes multiple times per day.
    I love my car, but I'm seriously considering starting a lemon claim. This will be the fourth visit for this issue, twice they claimed no trouble found until I showed them how to reproduce, finally they replaced the FWD sensor, but it was right as we went into fall and the problem only popped up once or twice during fall/winter. Now, in the peak of summer it's pretty much a daily occurrence.
  2. P85_DA
    P85_DA Supporting Member
  3. FamilyT3sla
    FamilyT3sla Member
    Riverview, FL
    Service center replaced the sensors in both of our doors for that exact same reason. Haven’t had an issue since the beginning of summer.
    They did state it was a known issue with darker colored model x’s.
  4. outie
    outie Active Member
    SoCal
    #4 outie, Jul 25, 2018
    Yep, I was the one who had this exact issue and just like you went through fall/summer before they could consistently reproduce it. I have started a thread about it before but most people don’t seem to have the issue or not as consistently bad as mine. It was a Midnight silver.
    They’ve replaced the sensors numerous time, the tripod assembly etc., and the last resort replacing the whole falcon door. It only happened on driver side but it started showing up on passenger side during the buyback.
    Long story short, Tesla ended up buying it back and I got a new one in pearl white. The new one is not without issues though!
  5. Krazaak
    Krazaak Member
    Charlotte, NC
    Interesting, I'd read through a few of the threads about it. I saw a couple fixed with door replacements and sensor replacements. I guess I can insist they replace the sensor again. NC lemon law is 2yrs or 24k miles and I'm just over 22k at the moment. It was a demo with 7700 on it at the start, so not sure if lemon would take that into account.
    I think I've had most of the standard MX problems, but still happy with the car overall. Mine's blue, so on the darker end of the spectrum.
  6. XHabjab
    XHabjab Helping to end the ICE Age
    Georgetown TX
    I had that same problem on the right side, although I did not correlate it with temperature. My Service Ctr knew about the problem and fixed it correctly the first time. Have your guys check with them in Austin TX.
  7. Yinn
    Yinn Active Member
    Behind you
    #7 Yinn, Jul 26, 2018
    Call BS. I had the same issue, it was bad enough to enter into calibration mode on occasion. I had to take it in several times but ultimately my sensors have been repalced which 100% resolved the problem.
  8. CUBldr97
    CUBldr97 Member
    MD
    Seem like a sensor and a software issue... or the tolerances in the sensors need to be re-engineered...good luck...
  9. Krazaak
    Krazaak Member
    Charlotte, NC
    So, as a followup, the SC added an oversized butyl patch to the driver's side FWD to help disperse the heat at the sensor and so far, I've had no phantom obstacles.
    Before 5 minutes in the sun was enough to trigger it and I've gone hours now without a problem. We'll see if it's a lasting fix.
  10. outie
    outie Active Member
    SoCal
    Do the sensors still function correctly? Ie still detect obstacles when there are obstacles?
    I think at one point they screwed with my sensors so that while the sensors didn’t detect obstacles under the sun, it didn’t even detect me standing right next to the door.
  11. Krazaak
    Krazaak Member
    Charlotte, NC
    Yes, I park in a fairly tight garage with the wall on the driver's side and it's working properly.
  12. Courtlandre
    Courtlandre Member
    Apex, NC
    I had a similar issue and they replaced the sensors, issue persisted. A mobile tech came out and replaced the black plastic piece towards the bottom outside of the FWD and no more issue.
  13. hypa
    hypa Member
    Los Angeles
    I also have this issue with my midnight silver metallic MX, they recommended a soft reset. I will be keeping an eye out for this.
  14. Willbebest
    Willbebest Member
    Canada
    i had my driver side sensor replaced 4 times in 2 years, and finaly they realized its not the sensor, its the carrier of the senor they call it "butyl path" which is not dissipating enough heat, the just installed additional butyl today.
  15. darktears
    darktears Member
    Portland, OR, USA
    Mine is a black Raven MX that I just got a week and half ago and I have the same issue. My driver side FWD sees ghost obstacles when there is nothing (sometimes even with a red symbol like I'm about to hit something). It's pretty hot here at the moment but still the passenger FWD doesn't exhibit any issue at all so I doubt it's related to heat. Also it happens even when I just get out of my garage in the morning on the driveway and it's not hot at all. I tried reset, hard and soft, cleaned the door and so forth, same issue.
    It's pretty annoying that I already have to go to a SC and wait a week to get the first available appointment. Not even two weeks of ownership. Don't take me wrong I love the car, I wish it would be more efficient and reliable.
  16. animorph
    animorph Active Member
    Scottsdale, AZ
    You can force the FWD to open by holding down any of the door buttons. I waited until my first (and second) annual service to get mine fixed. Of course we don't haul passengers very often.
  17. ToddS
    ToddS Member
    Jupiter, FL
    I was going to suggest a vehicle wrap (I have Xpel). I know you shouldn't have to do this, but I had a problem (not sure if it is was just a sun issue) and they replaced the sensors. No problems since.
  18. darktears
    darktears Member
    Portland, OR, USA
    For me holding down the door buttons (touch screen or physical) to override doesn't work, I get that horrendous beeep and they don't do higher.
  19. Kacey Green
    Kacey Green Member
    Charleston, South Carolina, United States
    Mine did this the other day when a small puddle on the sensor was detected as a solid obstacle on the roof
  20. darktears
    darktears Member
    Portland, OR, USA
    For the record the mobile team came in yesterday and it turns out that it was the sensor that unglued and ultimately giving false readings
