For those using this:
This assumes 291Wh/mi for the calculations, which means a
displayed value in the car for your lifetime trip meter of about
210-220Wh/mi (depends on assumptions; this assumes the 1.3-1.4 scaling factor, which is very reasonable in most less severe climates, with modest feature use). Very "best" case is ~240Wh/mi displayed in the car for a warm climate with no feature use. In a much colder climate (with preheating, feature use, etc.), you'd need to be getting about 195Wh/mi in the car, to have these calculations be correct.
So: depends on the situation, but generally this calculator will be
very optimistic for an EV which is being used to commute on freeways, or being used in the winter. In those conditions (freeway runs in winter at 70+mph, with Sentry mode used), it's very reasonable to expect 450Wh/mi from the wall. (So add 55% to this calculator's cost result for the EV for that scenario.)
Worth restating again: all of these calculations are impossible to generalize, since it depends very much on how many miles the car is driven per month (drives down fixed overhead cost), which features are being used, the length of each drive, and the climate.
The simple formula, using 1.3 multiplier on displayed Wh/mi for mild climates and 1.5 multiplier for harsh climates, gets pretty close to correct, but there are ways to do better, and worse.
