realvvk
As an ICE driver I immediately lift my foot when the light changes red in front of me. I then coast until I need to apply the brakes to stop. This is pretty much the way I was taugh to drive - it puts the least wear on the car, and uses the least gas.
I feel that this will change once I get my MS, and that i will "feather" the throttle longer but probably start regen before I used to start braking. Time will tell (hopefully not too much longer.)
Uh, no. Using the transmission to slow the car down would use even less gas. As an ICE driver you should also downshift when the light changes to yellow/red. When you engine brake above certain RPM, the fuel is cut off, so the engine uses less fuel.
