I did hard braking from 30 to 0 mph to see if the anti-lock braking was working. I had not touched the brakes before that test.
The result was a message "Assist for low brake performance activated".
The user manual has this explanation
"Reduced braking performance is usually
temporary, and can occur for a number of
reasons including high brake temperatures
after heavy brake use, or driving in extremely
cold or wet conditions. It can also indicate
that your brake pads or rotors have worn to
the point that normal replacement is needed"
I was surprised to get this message after a single stop from 30 mph. I repeated the test on different days with the same result.
I might not be surprised with this result if I had tried a panic stop from 60 or 100mph, but from 30mph I am surprised.
Any ideas?
Any ideas?
