I was trying to defog last night, and couldn't figure out how (voice commands didn't help, thought I was trying to turn on the dome lights).
Any way to manually activate it, tapping the windscreen heater twice changes it to max, but not sure if that is the same?
That was about to be my question this morning.If it was introduced prior to 2022.20.8 it doesn't stop the wing mirrors from fogging up mid drive when climate conditions cause this - common this time of year around here. They still need to be cleared by fumbling with the controls to manually put the heated rear window on which wasn't fogged up - and before anyone suggests, not a hope that voice control might help.
Last time I tried yes. But I was on V10 then and TBH, rear defrost was enabled with the full precondition from the app so its been even longer that I have actually used rear windscreen demist from inside the car.So side mirror are defogged/defrost only when using the rear defroster button?
Voice requires you to have an LTE signal and for the car to understand you. Fail on both these occasions.View attachment 864938
Or you can pin the front and rear screen heaters to the bottom of the screen.
The front screen heating has two levels by pressing it multiple times, roughly called Defog and Defrost, it just adjusts how much air/heat it blows onto the screen. If you have a 2022 model car, then there is also 'heated wipers' which is in the glass to defrost the area where the wipers rest. It's turned on with a separate control that's shown next to the heated wheel in the climate settings.That was about to be my question this morning.
And if I understand correctly front 'defogging' (button towards the top of the climate controls) just use the AC blowers on the windscreen, while front 'defrosting' will use the heated elements inside the windscreen?
Ah, okay. I assumed it was a heating element in the full windscreen like in my old Discovery. Good to know thanks!The front screen heating has two levels by pressing it multiple times, roughly called Defog and Defrost, it just adjusts how much air/heat it blows onto the screen. If you have a 2022 model car, then there is also 'heated wipers' which is in the glass to defrost the area where the wipers rest. It's turned on with a separate control that's shown next to the heated wheel in the climate settings.
There's no pleasing you is there? Did you notice there were no buttons before buying the car?Voice requires you to have an LTE signal and for the car to understand you. Fail on both these occasions.
As for pinning defrost, yes, along with all the other need to have at hand controls...
I turn on the defrosting for both via the app about 10 mins before I leave or 20 if it's actually frosty, never had a problem.Ah, okay. I assumed it was a heating element in the full windscreen like in my old Discovery. Good to know thanks!
Just needed defogging this morning (but the day for defrost will come ) , and I found the side mirrors were not defogging as quickly as the rest, thank god for the side cameras instead. Hopefully it's not a malfunction as it's the first time I was trying it...
I use a Siri shortcut automation on mine to precondition, defog and heat the steering wheel with a condition when humidity > 90% and temperature < 7°.I turn on the defrosting for both via the app about 10 mins before I leave or 20 if it's actually frosty, never had a problem.
Glad everything works perfectly for you all of the time.There's no pleasing you is there? Did you notice there were no buttons before buying the car?
Carefully avoiding mentioning that you can still have them there if you want, like I have, and like lots of other people have, not at all 'buried'.Glad everything works perfectly for you all of the time.
And btw, the defrost/demist buttons were there when we bought the car. Tesla subsequently removed them and buried them within the UI.
Not surprising that we are getting rid of the car and buying something different, you know, something that does what it was advertised that it would do when we bought it.
Press Defrost Car, it should go to HI, turn off Defrost and for me it then shows 20.The last couple of mornings it has been cold enough for me to open the app to warm up the car before leaving the house (I know, first world problems). Each time I have done this the app sets the car to "LO" and refuses to let me change it (yes, I've tried the arrow!). The 'red' indicates something is warming, but that doesn't seem to be the case. I've had the car more than 2 years, and this has never been an issue for me before...
I wanted the car hotter, not colder!
Has anyone else seen this?
How many other need to have buttons can you put there at the sdame time. Oh, im going out for a drive, now what weather conditions might I meet today so I can customise my UI to work in a safe manner... Fog lights x 2, manual driving lights (cos auto don't work in the fog), front window demist, rear window demist - I think i've bust the limit already...Carefully avoiding mentioning that you can still have them there if you want, like I have, and like lots of other people have, not at all 'buried'.
