Nice venue.
Run in EVX.MY QUESTION IS FOR 2023 what would my correct class be my club has no other EV competitors so can't help, thanks.
THANKS FOR INFORun in EVX.
P.S. what's up with the 2023 Solo rules draft only covering Tesla 3 through model year 2021? For that matter, it was the same for 2022 rules. Is that an oversight?
Or the '23P I just picked up is not gonna be eligible for the Nats somehow?
Still haven't sold my '19, but turned suspension back to stock before the winter. Wasn't planning on keeping it...
correction, they are NOT moving them just yet. They are requesting member comment about the possible moves.March 2023 Fastrack is out. Looks like they are moving the Model 3 back to BS
If approved, when will this move happen?correction, they are NOT moving them just yet. They are requesting member comment about the possible moves.
I will be submitting a letter in full support of said move. I suggest others do the same.
hopefully this season. but, we have to get the letters in before anything happens. and agreed, i will make reference to 2018- 2023 Tesla Model 3If approved, when will this move happen?
And should I submit a comment for them to bother updating 18-21 year range to 18-23?
Good question. I am not sure but it sure is fun with some camber and wider tires.So, is a M3P more PAX competitive in BS at 0.818 or in EV with some camber and wider tires at 0.832?
Was this ever ruled on officially? The single linkage per corner rule has so far made it only onto ST ruleset.EV-X applies to the Model Y as well.
However, I doubt you can run such aggressive camber in the rear without toe arms, and you can only do toe or camber in EV-X
Straight from the 2023 SCCA rule set, these are the eligible EV-X Teslas:Was this ever ruled on officially? The single linkage per corner rule has so far made it only onto ST ruleset.
