My Model S developed a musty/moldy odor, which the service center deemed as being due to dirty filters, after disassembling things and making sure there wasn't anything dead and decaying stuck in the car. They replaced the HEPA/cabin filters and the musty/moldy smell mostly went away, but still exists and is most noticeable if the car has been sitting off for a few hours. While most noticeable inside, trace amounts can be smelled outside of the vehicle in the garage when you are near it.
If the HVAC is run, it seems to help dissipate the smell and make it less noticeable, so it doesn't seem to be a result of running the system. I've tried switching back and forth between heat, A/C, and bio-defense mode, but none of these actions reproduce the smell.
Are there any others in between the filters and vents that may be dirty and will need to be replaced?
As I have another month to wait before service can look at it again (and then potentially longer until it can get to a service center - thanks, Michigan), I was hoping someone else may have some insight into what's happening. I did a lot of searching and couldn't find anyone else with this exact problem.
