The Model Y manual says I should use a ball hitch that has a 3/4" rise and is 8.5" from shank hole to pin hole. Where do you get something like this? U-haul has a ball hitch with a 1" rise and 10" from shank to pin - is that OK?
I would prefer getting an adjustable ball hitch so have the trailer level correctly at the correct height.
See various models and prices depending on the load capacity.
I bought a Curt 45030 ball mount with a 7 1/2" pin-to-ball length, looking at a video from eTrailer on a Model Y this seems to be fine and enough room. Got scared that I would have to return it for an 8 1/2" like Tesla specs, but that doesn't seem to be absolutely required. It has the 3/4" rise you're looking for.
Curt 45030 on a Y with factory hitch video: (Looks like it works perfectly)
I think you you measure the height of your tow hitch and the height of your trailer hitch from the ground,
to determine which drop or rise value you will need to use for your ball hitch.
Not all the trailers use the same wheel diameters and so on, also the MY Performance is lower than the MY AWD.
How to Determine the Proper Rise or Drop of a Ball Mount:
