Peteski
Sounds like a pretty useful piece of information to me. I wouldn't worry about it on a day to day basis, but I do a lot of long distance driving and it would be reason for concern for me if I saw a >20mi swing in my maximum range. Personally, I prefer rated miles view, because it gives two pieces of information instead of only one. You can visually see the state of charge (albeit less accurately) based on how full the icon is and you can see how many kWh the BMS thinks are in the battery based on the rated range. Showing percentage only gives one data point and it sounds like in the OPs case the battery was misreading capacity by several kWh. If I could switch the view to kWh instead of miles or percentage, I'd do that instead.
It would be helpful if the car also alerted you to excessive cell imbalance and suggested an overnight balancing charge to remedy it. My Zero SR app shows the cell imbalance value, which is pretty key to knowing if you're going to have an early battery shutdown as you get into the 10% or less range.
Yeah I just got fed up of the inaccurate rated range. I know a lot of people switch it to a simple percentage and use the energy page and nav for more accurate real world range calculations. My daily charge point is 80% and I only charge higher if I'm going on a longer trip. So I don't expect I will have any battery degradation issues to worry about.
When range is critical I just put the destination in the nav and observe the calculated battery state at the end. It is usually pretty accurate (within a percent or 2) unlike the rated range, which is wildly optimistic even when set to "typical". It certainly isn't my typical driving!
