Allistah
Here’s a recap from one of my posts in another thread. AWD with 9K, was charging a couple times a week to SOC 80% (rarely varied unless for road trip). Noticed a decline over summer from 310 down to 298. Switched to charging to 60% and after a couple times was back to 308 and as of last night it displays 310 rated range (using Stats).
Hey, that's great! Can you tell us more about your charges that caused this to happen? Are you using scheduled departure? Can you list out all the steps/charges that you did that lead up to this happening? I think there are a number of people here that would LOVE to try and duplicate your success!
On a side note, looking at a charge I did from about five days ago, it looks like the higher you get up in charge %, the bigger the gap is. Look at the "Range Difference" column which just takes the battery range and figures out what it should be if we got a perfect 310 miles at various "Battery Levels". For example, for 10% below, 310*(10/100)=31 (10% of 310 max miles is 31 miles) to get the "Perfect Range" column, then I just took the difference between the perfect range and the "Battery Range" which was reported by the car. The "Range Difference" grows further negative, the higher the charge got. I stripped out all the lines except the ones where it ticked over to a round number for this post so we could see a trend.
I guess this doesn't work in a single charge like I'm looking at. For some reason, I'm feeling like a scheduled departure is what is triggering this to happen for some reason.
