I have not replaced a ball joint since owning a 69 Dodge Charger (that was ~8 years old).
And I put a minium of 100k miles on any car and some I ran to 230k.
And I live in Pothole alley.
Sorry, but ball joints should NOT be going at 2 years and 60K miles. That is not normal.
Most any decent ICE car needs no service for 100K other than oil changes, tires and brakes.
12V I can accept because they might get used differently. And they look on the small side, probably to save weight.
These maintenance issues are chewing up the "No Maintenance" claim on EV's pretty quickly.
Oil changes are looking like a pretty minor annoyance.
Controls Arms
Tires
Alignments
Ball Joints
Lots of stress cracks in glass
12 V Battery
Oh and Brakes from LACK of usage
All seem way above normal.
I dunno about that. I used to be an "Audi guy". 60-80K used to be considered average for having to replace worn out control arms, ball joints, and tie rod ends. They would also begin creaking as rubber bushings cracked and wore out or the ball seemed to run out of lubricant. The same was true of shocks and struts. Even for people like me that did the work themselves, that got to be expensive over time. No OEMs provide suspension parts with integrated zerk fittings to grease them any longer either. That's a pet peeve of mine on suspension bits that take a constant pounding. Just because you no longer have an ICE or transmission to maintain doesn't mean that you're free from maintenance on all the other consumable items that take a beating (tires, suspension, brakes, etc). Anyone who bought into the "no maintenance" being slung around wasn't really thinking things through.
Best,
p.s. I've used the needle+grease gun trick a few times as well (watch the video above). It's a decent temporary fix if you can coax some of the grease into working into the joint instead of just swelling up the extra space in the dust boot.
