[Buyers group] IEC 62196 (Mennes) to J1772 cable (4m, 63A, single-phase)
Discussion in 'Tesla Parts for Sale' started by widodh, Apr 19, 2011.
  1. widodh
    widodh Model S 85 and 100D
    Middelburg / Venlo, NL
    #1 widodh, Apr 19, 2011
    [Buyers group] IEC 62196 (Mennekes) to J1772 cable (4m, 63A, single-phase)
    Hi all,
    I think most users here have been following the various threads about charging your Roadster on a public charging station. In the US most of these stations have a single-phase SAE J1772 connector, where Europe (NL, DE, UK and BE) are using mostly the IEC 62196 (also known as "Mennekes") connector.
    While the connectors differ in format, the protocol they use is EVSE, the same as the Roadster talks to the UMC or HPC (please correct me if I'm wrong!)
    Rumours go that Tesla will release a Tesla<>J1772 connector end of April or in May 2011, if so, we, as European Roadster users/drivers/owners will need a IEC62196 to J1772 cable.
    These cables are available for the Nissan Leaf, but most of them are limited to 16A.
    I've been e-mailing around to find a suiteable cable and I've come up with a Chinese supplier which can supply a cable which is able to handle 63A single-phase with on one end a J1772 connector and the other end a IEC 62196 cable.
    This image was taken EV-Box.com, as you can see, that cable is limited to 16A.
    The Chinese told me that they could deliver this cable for around $250,00 a piece, without shipping.
    What I'm trying to do is gather a group of people who would want this cable, so I can get them from China.
    I'd like to compile a list of people who would want such a cable, so I can see what I can do with the pricing and shipping.
    I'll ship the cables to my home (NL) and from there on I'll send them to you guys.
    The cable specs:
    Length: 4m
    Rating: 63A
    Side 1: SAE J1772
    Side 2: IEC 62196
    Phases: 1 (J1772 is single-phase)
  2. dpeilow
    dpeilow Moderator
    Winchester, UK
    Just a thought: The spec can handle 70A in single phase mode (63A is for 3P) so you should make sure the cable can do 70A.
    $250 is excellent though. There will be LEAF owners who want it at that price, for sure. I can think of 3 probables in the UK.
  3. Kevin Sharpe
    Kevin Sharpe Active Member
    Bradford on Avon, UK
    I'm interested.... please make sure that the supplier is prepared to CE mark the cable to avoid any issues you might have with the EU authorities (including getting it through customs).
  4. doug
    doug Administrator / Head Moderator
    Except that a 63 or 70 Amp cable is total overkill for them with that puny 3.3kW charger, even 6.6kW. Just a lot heavier cable than they need to be carrying around. How much is Nissan gouging for their Type 2 to Type 1 cable?
  5. widodh
    Yes, I'll ask them.
    About the 70A, as far as I know, no IEC 62196 station will support 70A, that max is 63A, single or three-phase. So 63A should be enough?
  6. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Also make sure that they use the ITT connector on the J1772 side as it is the only one that is rated to more than 30 amps.
  7. dpeilow
    dpeilow Moderator
    Winchester, UK
    More than twice as much, that's why I suggested it.
    The spec supports 70A so we may get stations that support it turning up.
  8. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    this sounds really good coiht me in but yes make SURE (you want to see their CE certification papers and make sure they are theirs!) it is CE certified so there are no insurance problems being blamed on a non certified cable in an accidental event........ that would suck.
  9. AndrewBissell
    AndrewBissell Member
    I will buy, assuming Tesla's J->T cable is not horrendously priced and this M->J is 70A capable. (There will I am sure be some European HPCs converted to Mennekes outlet sometime by someone.)
  10. widodh
    I also contacted the German supplier EV_de (forum user) suggested. They can't supply a 70A cable, their J1772 connector isn't 70A capable, they are limited to 32A.
    They gave me a quote of EUR 375,00 per cable (excluding VAT). This is a 5m cable (coiled).
    The Chinese haven't replied in the last few days, so not sure what's going on there.
  11. Lloyd
    San Luis Obispo, CA
    #11 Lloyd, Apr 21, 2011
  12. vfx
    vfx Well-Known Member
    CA CA
  13. AndrewBissell
    @vfx: just the connector?
  14. Lloyd
    San Luis Obispo, CA
    It's also the ITT Cannon J1772 plug
  15. vfx
    CA CA
    I believe so. Sign a waiver and get a plug. Don't know the markup.
  16. widodh
    I've been searching on the 70A topic, as far as I can tell, the IEC 62196 spec ('Mennekes') supports a max of 63A single-phase. J1772 might go to 70A, but IEC 62196 doesn't, so 63A will be the limit I guess?
  17. stopcrazypp
    stopcrazypp Well-Known Member
    J1772 is 80 amps max, but it's 240V AC, so 19.2kW max.
    But I think dpeilow is right, for single phase you can use up to 70 amps for IEC 62196-2:
    http://www.mennekes.de/web/screen?ID=mennekes%2Flive-browse-fresh%2F[lrncontent%2C[content%2Fpres.cnt.page-seqentry%2FmenP-31a786a9%3A12c19085951%3A-73c7%2F0%2F%2Ccontent%2Fexp.def-live%2Fen%2F\]]
    You can find plenty of sources of this if you google: IEC 62196-2 70 amps
  18. dpeilow
    dpeilow Moderator
    Winchester, UK
    Thanks Stop.
    The most up to date info I've seen on it is here. See slide 7.
  19. widodh
    Well, these Chinese stopt replying :( So I contacted another vendor.
    The German vendor isn't able to supply a 70A connector at this moment, 32A is their max.
  20. Kevin Sharpe
    That's not unusual... the moment you ask for approvals or CE marking then they tend to be less interested :wink:
