Yes correct, I noticed this week the following while watching SMT during my commutes:
- While -10C or warmer, AND battery is greater than 20% charge
The heat pump will draw heat from the ambient air through the Radiator+Fan and heat both the cabin and battery. Then when the battery reaches 16.5C the radiator bypass valve is activated and then active battery heating stops and the heat pump will now draw heat away from the battery. You will see at this point the battery inlet temp 1-4C colder than battery temp depending on HVAC settings. Then when the battery reaches 12C the radiator is activated again to heat both the battery and Cabin. This used up approx 1.5kW while battery heating and approx 800 watts while using the battery as a the heat source.
-While -11C and colder
I noticed in just one case this week that it used both the motor and radiator to heat up the battery. this used a whopping 3-4kw while the battery was around 0C. Again warmed up all the way to 16.5C.
- Weirdest thing i noticed in all this is that once the battery reaches 19%, the battery heating never stops. I arrived home one night at 15% battery and the battery at 17.5C. Battery heating continued even while in park. This is odd since it uses more power at a critically low level however im assuming this helps squeeze out and last bit of power.
Maybe we will get some -20C days here in Ontario soon so i can report out on what happens then more accurately.
