bodosom
Perhaps it's a model year constraint or your arms are broken. My wipers lift as documented -- just a bit so you can replace them.... the passenger wiper would not lift more than an inch or so off the windshield. Today, I took a closer look at the wiper arms. As the pivot point looked to be the same on both, I held down the base of the passenger wiper while carefully pulling the arm away from the windscreen and lo, the arm resisted but did raise to the upright position. And thereafter it pivoted freely. Tight rivet in the pivot point, I guess. At any rate, I'm relieved.
From the replacing wiper blades section (~page 176):
CAUTION: Wiper blades do not lock into a lifted position. Do not lift a wiper arm beyond its intended position
