There is a difference between jumpstarting a car and charging a battery. You could definitely use the Tesla to recharge someone's battery but that doesn't mean it has enough Cold Cranking Amps to jumpstart a car with a very dead battery.
Anyone know the CCA rating on the Tesla 12v battery?
Just like on the Prius I would aaaume the Tesla has a deep cycle battery and not one with much in the way of cold cranking amps as the Tesla does not need CCA (neither does the Prius since the starter runs on the main battery).
I am curious how bad jumping another car off a Tesla would be. When first connecting the terminals the Tesla 12v battery would try to equalize with the dead cars battery. This would drag down the 12v battery and presumably the DC to DC converter that keeps the Tesla battery charger would fire up and flow its maximum rated current? I presume it is self limiting and would cap out at some amperage?
Leaving it hooked up when trying to crank the ICE engine would be interesting as well. I think often times folks don’t realize how much of the starting effort of the ICE is still coming from the discharged battery or from the energy that was transferred to it after hooking it up but before trying to crank it. Unless you are trying with a dead flat battery, it only takes a little current to push it over the edge to start the ICE. Most jumper cables have really bad connections and can’t actially flow that much current.
So yeah, until we know more, I would avoid it, though there are a lot of things Tesla says not to do for no clear reason that folks regularly do anyway. (charging off a generator being one of them)
Note that the main difffernce between start batteries and deep cycle batteries is the thickness of the plates. The start batteries have more thinner plates which improves starting current, but makes them more fragile. Deep cycle have thicker plates but not as much CCA.
FWIW, I could see that dragging down the 12v bus during ICE cranking could cause unintended behaviors to Tesla electronics depending on a stabile 12v source. Probably just easier for Tesla to say not to do it than to actually test.
