That's my summation too; stop at Redding "just long enough to reach Mt Shasta charging". Thanks to you and PDX for the help!
I think you might be able to make it on a single charge. The route on 3 through Weed is shorter distance-wise (184 miles) but may involve more up and down and twisty roads (I have no idea).
Here is my Better Route Planner for this trip; it says arrive at 4% starting at 100%, with a route up I-5 (I turned off battery degradation, etc.):
A Better Routeplanner
It says 266Wh/mi - 25Wh/mi or so of that is due to elevation, and I think 240Wh/mi is probably high for the SR+ on this route.
It's hard to say - the up and down on this route will definitely hurt the economy, if you are forced to regen. Up-and-down is not great for efficiency if the hills are steep enough to force you into regen. Twisty roads don't help either.
This is a 4000-foot ascent, which, depending on how heavy your car is, deducts about 30 miles from the range (assuming 200 pounds of human in the car). If you have 300 extra pounds of people & stuff, that will add to the mile deduction a few miles (you'll get more miles back on the return as well).
But the SR+ is
SO efficient - it is rated for 247 miles in reality - so you should be able to make 217 miles in ideal conditions at these relatively low speeds for much of the route. You'd want to skip the AC, etc., of course.
These roads are slow (except for I-5 of course); looks like largely below 55mph, so it should be very efficient on that section.
I guess you just see how you are doing and keep an eye on the predictions on the trip planner in the car. It would be cool to see if it could make it. Not ideal for the first long trip in the SR+ though.
You have to be sure before heading up the grade to Mt. Shasta, of course. The good thing is that the really efficient section is first, so you should get a good idea.
The return will be no problem at all; you don't even need to charge to 100% - and you shouldn't since you'll be starting out downhill (I would do 85-90%, but it would depend on how I actually did on the outbound leg). Here is the return:
Honestly, in an SR+, I really think you could make the outbound route, if you were experienced at driving efficiently, just used the fan for cooling, dry conditions, no significant headwinds, etc. It does require that environmental factors be ideal, but the warm weather will improve your efficiency, if you can avoid AC most of the time.
Keep in mind you can drive a few miles below 0 rated miles (maybe just 2 if you are going uphill!). Not recommended though. Especially not with a brand new car you don't know.
