Can I exit the car and then have the X parallel or perpendicular park?
If yes, how I do that? I only know how to start the parking process when I put the car in reverse.
Thanks
I can't get my parallel or perpendicular park to work.
My car was delivered at 17.28.50
So autopark is not really auto parking then? It only pulls in to your garage?
Summon is not automatic parking, no (though it was somewhat promised to be at some point.)So autopark is not really auto parking then? It only pulls in to your garage?
The X parks much better than me. Fast and quick. No fuss no miss.
Good summary!I think you are confused.
Your X can parallel park or perpendicular park (back into a slotted space) by itself, but not after you exit the car. You cannot, for the moment, exit your can and expect your Model X to snoop around for a parking spot and park itself. The features you are hearing about are Autopark and Summon, they are two different things.
Autopark works like this:
1. Drive slowly until you pass by a viable spot
- for parallel the spot needs to be defined by two cars with enough space nose to tail, and against a curb. You must be going 15 mph or slower2. When a viable spot is detected by the car, a "P" will appear on your instrument LED display next on the side of the car where the spot was detected.
- for perpendicular parking (my HW2 car needed FW 17.24.28 or higher) you need to pass by an empty slot sandwiched between two cars and going slower than 10 MPH
3. Stop, hold the brake, put your car into reverse.
4. On your main screen, tap the auto park
5. Release your brake. The car will park itself. You can pause by hitting the break or abort the park by braking and putting the car into drive.
Summon is a feature that allows you to line your car up into a parking slot but not back or pull into that slot. You can then exit the car and use the summon feature to put the car into the parking slot. The car will use the sonar sensors to avoid collision and will stop within a predetermined distance from a detected obstacle in front (forward summon) or behind (backward summon). Summon is useful if you want to park in a spot is so tight you would not be able to open your door and exit, similarly if you are parked you can pull your car out of the tight spot for easy entry. You can use your phone app, keep app, or set it to summon park before you exit the car.
I prefer to use the key fob, here is the procedure:
1. Line your car up to the parking slot you wish to use but do not back or pull into that slot (if you are already parked and are leaving, skip this step)
2. Exit the car.
3. Press and hold the top of the fob (that would control the doors) until you see the headlights flash
4. Push and hold the trunk button (to back into or out of a spot) or the frunk button (to pull into or out of a spot).
Summon is a bit of a misnomer in my opinion, it implies that you can summon your car to you just like a valet.... they are not quite there yet
2. Exit the car.
Found out yesterday my X would not summon going backward on a slope parking lot
Interesting, my AP2 X can summon backwards onto my driveway, and it's pretty steep.
Doesn't go forwards though.
Make sure in summons customize, set "continuous press" to OFF. Then press & hold fob top button long, until orange lites blink, then press frunk or trunk for direction. You can also customize the distance etc.Wow thanks for the awesome post. The tip with the key fob is extremely helpful. Now can Summon my car without using the app. Do I have to keep pressing the key fob. How long do the batteries last on the things.
I use the Summon feature often to get my car out of the garage
