Can you keep the 12V outlets on when the car is off?
Discussion in 'Model X' started by ecarfan, Jan 2, 2017.
Tags:
  1. Gwgan
    Gwgan Almost a wagon
    Maine
    Wasn’t there a post here about accessible constant power in the trunk opposite the 12V receptacle?
  2. GOPJEW
    GOPJEW Member
    Potomac, MD
    I think I used the bottom two wires. Need to go back and check
  3. ShawnA
    ShawnA Member
    Edwardsburg, MI
    Hi GOPJEW,
    Hopefully are cars are the same.
    In the connector to the 7 pin trailer connector are 3 large wires.
    They are brown 12V-negative, red 12V+positive, and yellow with a red stripe.
    The yellow with the red stripe is the 12+positive output from the brake controller.
    I need to know if you "extended" the wires from the 4 pin connector where you connect
    the brake controller to the trailer connector.
    By rights the positive 12V should be powered in the 7 pin connector without any action
    by the car owner - It is supposed to be ON...
    Again, all that I am using it for is to power the breakaway battery and a 5 watt interior
    light in the utility trailer
    Thank You,
    Shawn
  4. unpollo2
    unpollo2 Member
    atlanta
    just keep the car in the old camper mode, when in D don't push P to park but select the emergency brake from control panel
    you can turn off HVAC and put screen into cleaner mode and lock the doors with the keyfob 20 feet away
    keeps all 12V sockets on
  5. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    What about this tweet today from EM and selected powered devices for 48 hours?
    Elon Musk on Twitter
  6. SongjinDK
    SongjinDK Member
    Turn on the climate with your phone remotely will also turn on the power, I tested for a few hours and it doesn't seem to turn off. Camper mode does not work, the power will turn off after a while.
  7. mattack4000
    mattack4000 Active Member
    You could also run a long extension cord after you put in a female plug at the trailer plug
  8. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    "All signals, lights, and brakes work fine. Just no 12 V+ out of the connector.
    I am capable electrically and the power is just NOT in the connector."
    My F150 while towing my Airstream has to have the lights at first click turn on for the trailer backup camera. to receive 12V.
    The reason I use the F150 and not my X. we decided we wanted the 28 ft. When the Tesla pickup comes out. I will be selling the F150
  9. unpollo2
    unpollo2 Member
    atlanta
    i tried this as well and it does seem to work. turned HVAC on via phone app and the rear 12V powered on and has been charging my scooter back there for the past 3 hours.
    old camper mode works also but u have to have seat belt extenders to register someone in the front seat
  10. UncaNed
    UncaNed Member
    East coast
    Does this mean I have to have the heat or AC running the whole time if I want to power a little inverter or something during a power failure? Last week I had no power for two cold nights, but was saved by a 120 watt inverter and my Tesla's cigarette lighter so I could run my internet, an LED lamp, 50 Watt heating pad and internet. I had to keep closing and opening the trunk door via the app every time it shut off though.
    How else can I have enough continuous or almost continuous 12 Volt Tesla juice so I can have 120 AC watts next time this happens? Hook the seatbelt and put something heavy on a seat or something?
    -2018 Model X with tow hitch
  11. SongjinDK
    SongjinDK Member
    For bigger power inverter, you can connect to the jump start post in frunk. It's fused at 80 amps, so you can use a 800w inverter. If you need a bigger one, you can connect to the 12v battery, which will give you 200 amp, you can use a 2000w inverter, make sure turn off HVAC to avoid overloading the DCDC converter, which is rated 2500w. But it may need to run HVAC to warm or cool the battery, so it's safer to use a inverter with 1500w or less.
  12. UncaNed
    UncaNed Member
    East coast
    Thanks for the help! Where is the jumpstart post? Is it always powered? What era and model did you hear about having that? My X is March, 2018 build - would mine even have a jumpstart post? I wasn't necessarily looking for more power, but powering my 400 Watt inverter would be a dream come true next time the power fails.
  13. SongjinDK
    SongjinDK Member
    Here is an instruction:
    I think he has 17 or 16 MX, mine is June, 2018 MX, so it has always been there.
    He tested a 750w:
    He said it is unfused, but it is fused at 80 amp, which should be good for up to 800w.
  14. mattack4000
    Just buy a Polaroid ps600 pure sine wave portable and they run a long time. It’s safer than blowing up a $100k vehicle
  15. SongjinDK
    SongjinDK Member
    That's good solution to power up laptops and phones, but it's less than 1kwh. With 75kwh or 100kws batters (equivalent to 5 or 7 powerwalls) we can power the whole house for weeks. Only difference is the power output, powerwalls can output 5kw (7kw peak), we can only do 2kw..
  16. SongjinDK
    SongjinDK Member
    I looked up the service manual, the jump post is directly connected to the 12V batter positive without a fuse. It is connected to the DCDC converter through a 250A fuse. So he was right, it is unfused.
  17. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    Not sure where you are getting your data... the Tesla wiring diagram shows a 50A fuse protecting the 12V charging post :cool:
  18. SongjinDK
    SongjinDK Member
    #118 SongjinDK, Nov 30, 2018
    That diagram is for 2014 Model S, I looked up from the 2017 Model X service manual. There is cable connects the Jump Post direct to the 12V battery positive terminal. The part number is: ASY,CABLE,MDLX,LHD,12V+ 1036883-00-E
  19. FlatSix911
    Silicon Valley
    Can you post a copy of the diagram... I thought the jump posts were eliminated after 2016:cool:
  20. UncaNed
    UncaNed Member
    East coast
    How much power could I get from the trailer plug on a 2018 Model X75D?
