CHAdeMO Charging the Model 3
Last night I received the 2019.24.4 software update for our Model 3. So this morning I tested Tesla’s CHAdeMO adapter to determine the rate of charge, and see how many miles I’d get and how long it would take to charge from a given SOC. Summary: 45 minutes gave me 139 miles of rated range and cost $8.69. Tesla’s CHAdeMO adapter is easy to use and provides more charging options for the Model 3.
A DC charger at a charging station in Sacramento.
This site where I charged has one DC charger with dual plugs to charge EVs with either CHAdeMO or CCS charging ports. It can charge one car at a time, delivers a maximum of 125 amps, and provides maximum power approaching 50 kW depending on factors such as state of charge, battery pack temperature, etc. I arrived at the station with 126 miles of rated range – 39% SOC – in our long range RWD Model 3.
I arrived at the station with 126 miles of range / 39% SOC.
If you haven’t used CHAdeMO chargers before the plugs are substantial, and by that I mean big. But using the adapter, while not dead simple like a Supercharger, was straightforward and easy: I removed the CHAdeMO plug from its holster on the charger, connected it to Tesla’s CHAdeMO adapter, and plugged the adapter into the Model 3’s charging port.
This station is operated by Greenlots. To start a charging session you either call their 1-800 number, use the Greenlots phone app, or a Greenlots RFID card. I have a Greenlots account and their RFID key fob so I held the key fob next to the labeled sensor on the charger and it verified my account. The charger provides you with easy to follows instructions. I pressed the button to select the CHAdeMO plug, and then pressed the button again to start the charging session.
I connected Tesla’s CHAdeMO adapter to the charger plug, plugged the adapter into my Model 3 charge port, and used an RFID card to start the charging session.
The charger delivered 22.8 kWh in the first 30 minutes, providing about 90 miles of rated range.
This DC charger sent 23 kWh to the Model 3 in 30 minutes, adding 90 miles of rated range to the pack.
The session started with the charger delivering 42 kW when the battery pack was at 39%. The power slowly increased, hitting 49 kW when the battery pack reached 80% SOC. I didn’t charge long enough to see where the taper would begin, but I’m guessing that would be in the range of 80-85% SOC.
It took a total of 45 minutes to go from 39% to 81% SOC. This included the time it took me to plug in and initiate the session. In 45 minutes the charger delivered 33.7 kWh (according to Greenlots), adding 139 miles of rated range to the pack.
The charging session started with the charger delivering 42 kW at 39% SOC, and the power slowly increased hitting 49 kW when the battery reached 80% SOC.
At this location Greenlots charges 25¢ per kWh, plus taxes and a 35¢ session fee. Total cost for this charge was $8.69, so just under 26¢ per kWh, which is comparable to the cost of using a Supercharger. The cost of using CHAdeMO chargers varies depending on the network that operates the station.
CHAdeMO charging stations are not Superchargers, yet. Some of the new stations coming online provide more than 125 amps, but I believe Tesla’s current CHAdeMO adapter will accept no more than 125 amps (please correct me if I’m wrong). CHAdeMO chargers don’t span the entire country, and generally don’t have as many charging stalls per site compared to most Supercharger locations. But some regions of the country have a good number of CHAdeMO charging locations that support EV drivers. So while 139 miles in 45 minutes is slower than a Supercharger, it’s better than L2 charging. Most importantly this gives us more charging options for road trips and regional travel.
I’ve used this station before to charge our 2012 Toyota Rav4 EV, thanks to Tony Williams’ CHAdeMO charging port, JdeMO. Adding the CHAdeMO charging port to our Rav4 EV expanded the horizons of that car, and I expect the CHAdeMO adapter to come in handy for our Model 3. I don’t expect to use it for local charging, but plan to use the adapter on longer trips we have planned.
Quick charging my 2012 Rav4 EV at this station several years ago.
If you are new to EVs and want to know how to find CHAdeMO charging stations, Plugshare is a very good resource. Go to that website (or download the phone app), click on the filter tab, and select CHAdeMO (or any other type of charger) to find charging locations near you.
Screen shot from the Plugshare.com website showing the location of CHAdeMO charging stations in the Atlanta area.
Final note: In the United States the two non-Tesla DC charging standards are CHAdeMO and CCS. The CHAdeMO charging standard was designed and promoted by Japanese power companies and auto manufacturers including Nissan and Mitsubishi. The Nissan Leaf, which came on the market in 2010, is the best selling EV with the CHAdeMO port. Other auto manufacturers use the CCS DC charging standard. Cars with the CCS port include the Chevy Bolt EV, BMW i3, VW e-Golf, and other European made EVs coming on the market. Ultimately cars with a CCS port will outnumber those with CHAdeMO. At some point Tesla may sell a CCS adapter for use in the United States, but there’s no indication of that yet.
This guest post from Steve Noctor originally appeared on his blog It’s Electric
@RayK EA is free right now thanks to some reports (Electrify America complimentary sessions (stations set...). I can confirm that Kooser stations are showing complimentary session. I'm using a CCS plug for free right now.
Thanks for the heads-up. I charged yesterday (Tuesday 11/23) at the Water Company and had two others pull up during my session; a Bolt and a Mustang Mach-E. Very rare that somebody else drives up when I'm charging there. The Bolt used the second DCFC station that I thought was reserved for Company employees but apparently worked for him. I cut my charge short for the Mustang, stopping at 80%.
Most likely I'm not going to be driving anywhere on Turkey Day but I might take a trip to the coast Friday or Saturday so I could use the free electrons....
The "non-public" station over there (I think DC1) used to be available to the public between 5 am to 11 pm on Saturdays and Sundays. Outside that, it would deny you. I guess it would allow employees (thoes in the water district's connections group) to access 24/7. But, sometimes, its time clock was way off so it would let you use it with either the ChargePoint app or card at odd supposedly "closed" hours. And, I think if you started it from the EVgo app (via their partner roaming), it might let you use it within the restricted hours. (Long story as to why I was doing that.)
Not sure if they altered that now. DC1 now shows opening hours of 5 am to 11 pm every day of the week. I haven't used those DC FCs in awhile, but whenever I go there, I attempt to use the "non-public" DC FC first since many people don't know about it. That way, I leave the public one open for others.
@cwerdna Checked into the EA charger at BofA (Winfield) on Friday and received my free charge (30kWh). 120 miles of range added in about 50 minutes and saved me $11.61, if I really wanted or needed to pay $0.42/kWh. From doing the math, it looks like they only charged me for 27.64kWh yet the display said I consumed 30kWh. Maybe there's a ~10% overhead figured in? Or do they round up? It's only my second time using the EA CHAdeMO station and the first time the sun was shining onto the screen so I really couldn't see anything.
Reactions: cwerdna
Yeah. I've seen the stations on Winfield facing the sun when the sun's beating down on them. I think the LCDs actually overheat as the anywhere from 3/4 to 90% of the bottom part of the screen is unreadable (e.g. black) in sort of a big splotch. It's not glare as shading it w/your hand doesn't help. It's a good thing they have those hardware buttons underneath the 3 labels on the screen in the event the touchscreen doesn't work.
At night, the screens there are fine. At Winfield, the station facing away from the sun was readable while the other two facing the sun weren't.
I sucked down north of 64 kWh of free CCS juice this weekend, mostly from EA.
Reactions: RayK
@RayK and @Randy Spencer:
As I mentioned at Electrify America complimentary sessions (stations set..., EA is doing unannounced free juice again. Not sure how widespread it is. The unit next to the one I'm using as of few minutes ago is still showing complimentary session.
I wonder how long this will last... If you're up now, might want to check. If you're coming out in the morning, might want to swing by an EA station w/your CHAdeMO adapter to see if it's still free.
I can confirm it was free at another EA site in Silicon Valley closer to home after I departed from the earlier one. I wonder if this is due to a upstream systems outage or upgrade or part of some other holiday plan.
There was no message on any of the chargers mentioning holidays, an end date and time or anything like that.
OK, I just tried the one here in Alameda, CA. No holiday message, but it did say "Welcome, Free", like that was my name, "This session is complimentary, courtesy of Electrify America." I just pressed the CHAdeMO button and then the No Receipt button and it charged up my wife's car w/o any indicator it knew who I was, saved me 86 cents!
Yeah, tiny battery.
Reactions: cwerdna
Looks like it's off peak only, I just went again now and it's back to making you sign in to charge. Wonder when their peak hours end.
Maybe... weird... I went out for a bite to eat and shopping. Stopped by another EA site near that eating place in the South Bay and it was free at 9:26 pm 12/22 so I picked up juice again. After eating and shopping, I dropped by another EA site near home (used yesterday) and it was free still/again at 10:22 pm, so I topped off.
It seems like it is/will remain unannounced given
Code:
https://twitter.com/ElectrifyAm/status/1473457099078356993?s=20
As I posted at Electrify America complimentary sessions (stations set..., some EAs stations are showing "This session is on us..." mentioning that select (not all) stations have free charging from Dec 22 3 am EDT to 3 am EDT Jan 3. And, as usual, they reserve the right to cancel or modify the offer at anytime.
Some folks confirmed receiving free juice and some no. Someone called EA support and they wrote:
"I called EA. There was a very few chargers in the network set to free charging. Those units were having some firmware work done. Not all (mine included)were part of the feebies."
I wouldn't make a special trip out to check but if you're in the area, might be worth it to swing by.
