CHAdeMO not fully charging the battery
Discussion in 'Model X: Battery & Charging' started by Ghostrider, Oct 8, 2016.
  1. Ghostrider
    Ghostrider Member
    Woodinville, WA
    Decided to try out recently purchased CHAdeMO adapter. Plugged in, gave EVgo a call and charging started. 400V 100A. However when the car was around 92% (~10 minutes later) I received charging stopped notification. Gave them another call to restart charging and again it stopped right away.
    Charge limit was set to 100%
    Anyone else experienced something similar? Is it more likely to be car, adapter or charger issue?
  2. Oceanwolf
    Oceanwolf Oceanwolf
    Morgan Hill, CA
    I used my adapter on the DC Fast charge on Thursday. I was at 100% at the end of the charge.
  3. Aljohn
    Aljohn Member
    Georgia
    Those last few miles cause the battery to slow from the 100 amps to a mere trickle. It is possible the charger was set to stop at less than 10 amps. Even the Super Chargers slow significantly when you reach over 90%. When traveling, I have found it is a waste of time to try to get the battery to 100% if you have enough charge to reach your next charger or destination. With the new "round trip" alert in 8.0, 100% may be a requirement in some cases to get back to the charge location. Don't think like an ICE by topping off the tank to the nozzle, you only need charge to get on your way to the next stop, even if that is only 50 or 60% of the range. Makes for mush faster long distance travel.
  4. davewill
    davewill Member
    San Diego, CA, US
    Some CHAdeMO chargers allow you to select a charge percentage on screen. It's possible that that particular one is set to a lower percentage (even if there's no on screen selection). It's also possible that it isn't fully compatible with the Tesla adapter. I'd report your experience to both EVgo and Tesla to see what they might say.
  5. Redmiata98
    Redmiata98 Member
    Northern Virginia, USA
    How long ago did you get your adapter? There was a firmwear update that they had to do to mine before I picked it up in August. Perhaps there is an update that needs to be made?
  6. Ghostrider
    Ghostrider Member
    Woodinville, WA
    Picked it up in the beginning of October.
    Did they have to do an update to the adapter itself or to the car?
  7. Redmiata98
    Redmiata98 Member
    My adapter required the firmware update.
  8. cclemon8
    cclemon8 New Member
    Irvine, CA
    Did you guys just go to the SC and ask them to update the adapter's firmware? I had similar issue with an EVPump charger today. Charging stopped at 70%
  9. Redmiata98
    Redmiata98 Member
    Call Tesla to find out if it is required, mine was updated during the purchase process.
