It's not that simple. The middle row in a 7 seater is totally different than a 6 seater. The 6 has power middle row and the 7 is manual not to mention the seats are bucket on the 6. The seven is a 60/40 split bench. Long story short is that it can not be changed. It must be configured when ordering. The main reason a 6 is more money is because the 2 middle seats are powered. The other main difference is that the middle row on the 6 do not fold flat like the 7. Hope this helps.You will need to track down a new center seat. I assume it's a quick swap. Manufacturers generally use the same body regardless of the amount of seats used. It will either use the same mounting points or there will be mounting points for the 3 seater middle section under the carpet. As Richbuilds has noticed with adding rear seats in the rear of model S's. They come with the mounting points in the back regardless if they came from the factory with or without the rear seats. Now the question I would be asking is if you install the new seats how will the rear heated seats work now that there will be 3 instead of 2?
Better off trading in for a 7 seater if you must have 7 seats.
