at home, I’m getting a warning that says charger temperature over limit. Charging interrupted.
Charging at work is fine.
I tried again, charges for a few minutes then stops. Same message. Pretty sure it is the wall connector or the cable that is faulty but how can I fix this? Can I just change the cable and not the whole wall connector somehow or are they attached.
Had the same issue a few weeks ago but when I decreased from 48 amps to 40amps the problem went away. Now back again even at lower amp of 35.
charging at work is fine no issues with different cable.
Any help would be appreciated!
