That means you have
at least 3% battery degradation very recently. The car estimates how much energy is going to go into the battery to reach target SoC, then recalculates once that energy is added. Since there is less overall capacity due to degradation, the final SoC % is higher than target.
Na, I’m messin’ with you.
It’s a common thing. Car targets whatever you set, but sometimes overshoots the amount when balancing the cells. You’ll find a number of threads on this subject. Don’t worry about it.
Since installing a Wall connector my car charges to 81-84% when set to 80% Is this normal? when charged with mobile connector it still overshoots but not as much. Usually to only 81%.
teslamotorsclub.com
I've noticed a strange behavior in the last couple of days, it's charging beyond the set limit. Friday I set the limit to 85%, in the morning the battery level was 89%. Last night I came home from a road trip and lowered the limit to 75%, in the morning it was 78%. I've had the car for four...
teslamotorsclub.com
