There are plenty of threads around here on that topic. Short answer: yes it's normal. Charge percentage is an estimate, not a fully precise value. BMS recalibrates after charge and value can change, temperature affects it etc...
I've found I often lose 1-2% in the morning after the battery cools off, and I then gain a percent or two late in the afternoon when it's hot out. Today I went from 49% when I got home from dropping my son off at school, to 52% when it was time to go get him.The CAC value fluctuates with the temperature
All first-time Tesla owners care a lot, actually.Who cares?
Was set to 80%From what SOC did you charge when it overshoot to 84%?
What Y is it? LR / P or RWD with LFP battery?
The car (BMS) can not measure the real SOC during a charging session.Was set to 80%
Started at 35%
it’s a MY LR
using a Wall Connector at 48 amps charge
Which car model?Interesting
I have mine set to 80%
Sometimes it charges to 82%, but never above that.
To add: I am using a Chargepoint Homeflex with the Tesla J1772 adapter.Mine always stops right at the charge limit, and then sits there. Haven't seen it fluctuate up or down until at least the next day or two, when the percentage may go down by 1.
