Hi good morning,
Since I have solar I like to be "green" and charge directly from the sun during midday when it produces the max output (I also avoid the roundtrip of energy to SDG&E).
For the past couple weeks, I've noticed the charge drops from 48A to 32A when charging midday on a sunny day.
The Wall Connector is fine (cool, no heat), backed by a new 200A panel with a 60A breaker.
After doing some testing when there's no sun it maintains 48A charging just fine (night or early morning).
I will do one more test today midday, but I've noticed with peak solar the voltages hovers around 243V.
And within minutes the charge rate drops and stays at 32A.
Would the slight increase in voltage be a factor?
The update to the latest firmware 2019.16.2 didn't change anything.
