WannabeOwner
I'm curious as to when 13AMP charging breaks even with Off Peak plus a Wall Charger
4 hours (say) off peak, assume 7 MPH - that's 28 miles (10,000 p.a.) - more than the average consumption ... but it would have to happen evenly - if the user drives 10K p.a., but only one day a week, then most of that will be at Peak rate.
Assuming Wall Charger is £1,000 and Peak Electricity is 40p and off peak 10p so 4 miles at 40-10 = 30p saving - so 7.5p per mile cheaper.
£1,000 / 7,5p = 13,000 miles. Say a payback of 3 years is acceptable that's 11 miles a day
So basically for someone doing 28 + 11 = 40 miles a day average or 14,250 p.a. then Wall Charger would be cheaper.
In practice, given that daily mileage would be "lumpy" it would be less than that.
Also, its debateable whether Off Peak is worthwhile for 13AMP car charging ... Peak Rate will be higher for all other usage, and actualy Off Peak usage will not be anything like as much as with a 7kW charger ...
There are also rates for car charging based on kWh added to the car (rather than a 4-hour window) but I don't know if they are available to 13AMP charging?
