I have a non Tesla Smart Charger that was causing a problem by tripping the breaker or going off line. I called the installers to try and get it fixed they eventually came and installed a ground earth link. Since then it has only charged at a maximum of 16 amps. I had reduced the max charging rate to 16 amps in an attempt to prevent the tripping. It had previously charged at 32 amps. I have been complaining to them that it will not charge above 16 amps but got a reply to ask if I had set a max charging rate I thought that I hadn't as I have been able to charge at Super Chargers without a problem. Having read the reply from my installer I looked at the hand book and saw that it said the car would remember the max charging rate at that location. It cant be set higher than 16 amps on the slider. So am I stuck with a maximum charging rate of 16 amps at home or will a power down reset fix the problem or does anyone else know of a way to sort this?
The car
should enable you to set any amperage up to whatever the EVSE supports, even if you'd previously set a lower value. I know I lowered and then raised my Model 3's charge rate once or twice myself, when I was playing with settings. This was soon after I bought my car over two years ago, though, so it's conceivable that there's a bug in whatever software version you're using. I doubt if that's the case, though....
My hunch is that you've set a limit in the EVSE itself, independent of the circuit rating or the settings in the car. You don't say what brand/model EVSE you have, so I can't help you find the relevant setting -- and I wouldn't know for most brands/models, anyhow, but somebody might. Some EVSEs have a physical setting (DIP switches, a dial, etc.) that can be used to adjust the maximum amperage. Others, with network connections, enable doing this via an app or Web interface; this is how the JuiceBox units work, for instance. Some are permanently fixed at one setting, but my hunch is that yours is adjustable, and it's been set incorrectly.
If the problem
is in the car, then I doubt if a system reset (holding both scroll wheels down on the steering wheel) would help, but you could always try that -- it only takes half a minute or so. It's more likely that a full reset to factory defaults would help -- but this would cause you to lose
all you settings, so I don't recommend you start with this. Investigate the possibility of a mis-configured EVSE first.
