Charging problems
I have a 2016 model x with just under 100k miles. I have the wall charger that started off at 48 amps then earlier this year it dropped to only 24 amps. Then it started to not charge unless I inputted and plugged back in. And now it barely ever charges, I've tried other charges and same problem. It works fine if I go to a super charger. Has anyone else had this problem?
Have you tested at other L2 chargers? Have you tried charging another car at your charger? Can you pull error codes? I'd start there and determine whether it's isolated to your car, or your charger.
I have tested other chargers, the only charger that works is the supercharger. But what I don't get is that every once in awhile the wall charger will charge it for a week or two then it stops.
