Note
For 3-phase charging (if applicable in your region), the available current represents the current per phase (up to 32 amps). During charging, the right status flag displays the 3-phase symbol in front of the displayed current.
Thank you.3 phases of the charger. 22 kwh chargers are 3 phases. 7kwh are 2 phases
I don't remember if come with v11 or was beforeCharging at a 50kw public charger and for the first time I’ve noticed the green regen bar pulse from left to right when the car is charging!! Was it always like that? Sherlock Holmes I’m not..
7kwh is single phase but otherwise right.3 phases of the charger. 22 kwh chargers are 3 phases. 7kwh are 2 phases
To be more correct, the car will charge at 22kW on a three phase AC supply and 7kW on a single phase AC supply. A kW is a measure of a rate of charge (how fast the electricity is coming out of the supply) whilst a kWh is a measure of the amount of supply (how much electricity has been been supplied).3 phases of the charger. 22 kwh chargers are 3 phases. 7kwh are 2 phases
Model 3 will take only 11... mine I see taken 12 and at home 8.To be more correct, the car will charge at 22kW on a three phase AC supply and 7kW on a single phase AC supply. A kW is a measure of a rate of charge (how fast the electricity is coming out of the supply) whilst a kWh is a measure of the amount of supply (how much electricity has been been supplied).
Sorry - you are right about maximum Model 3 rates of charge on AC. I was only thinking about getting the units correct!Model 3 will take only 11... mine I see taken 12 and at home 8.
Yes indeed … though interestingly the car’s onboard charging circuitry consists of 3 modules at 16 amp each. Single phase 7kW charging uses 2 of those modules for the standard 32amp whilst three phase uses all 3 modules for 48 amps.7kwh is single phase but otherwise right.
6 kW is the current amount of power it is pulling, +14 kWh is the amount of energy used during the current charging period. Assuming it has been at 6 kW all the time it means you have been charging for around 2h20mins.it’s just this 6kw + 14Kwh information is bugging me
I have had my Model3 for 2 years and still follow MR M's shipping updatesGreat thanks for sharing your knowledge guy’s, I fully understand now.
I do feel quite honoured to have a response from Mr M. I’ve being following your shipping updates in the months before I took delivery of my Y in Sept. Brilliant, Thank you.
