Amazon was kind enough to accept a late return. They said there might be a restocking fee, I can probably escalate and get it waived. So $635 after tax saved.OP were you able to get your money back on the ChargePoint EVSE?
I’m assuming your electrician matched your wiring and recepticle to the ChargePoint EVSE you bought and that is why you have a NEMA 6-50 recepticle and only a 40A breaker installed. Switching out the breaker probably wouldn’t be a big deal if you have the capacity but he might have used smaller guage wire. At this point I suspect your best and easiest and cost effective route would be to pick up the $32 NEMA 6-50 adapter to use with your UMC cable. Your still getting a good charge rate for overnight use.
To compare when we had our installation done when we bought our Model S, we went with a 50A breaker and a NEMA 14-50 recepticle. We decided to use Tesla’s Corded Mobile Connector for snugness to the wall because we felt with our garage we would be bumping into the HPWC. They were both about the same cost. Now we have a Model 3 in addition and use the corded connector (pretty much permanent install for all practical purposes) to charge both cars. I was getting 33 mi/hr at 36A so a little better than your recepticle connection. Overnight charging which both can easily do, doesn’t really make the difference. If you were able to get a refund for the return of the ChargePoint, I think you’re doing fine with your setup overall.
I just ordered a 6-50 Adapter, so going with easiest road. I generally charge overnight, so I’m ok with 30 miles/hr charge.
