Thanks for the replies. We have a 220 volt and I bought the adapter but were only intending on using that for a backup. I don’t drive a lot and I have time and we just thought I’d always use the supercharger .5 miles from my house. From what I’m reading this is bad for the battery? Is that correct? It is better for the battery to constantly charge at home right?
- nobody actually knows which is better (fast DC charging or medium speed l2 charging or super slow l1 charging. Tesla probably knows more than most people, but even they are still learning.
- DC Fast charging needs to heat the batteries up to the top end of their stable temperature, but the batteries spend way less time in "charging mode"
- Slower charging puts the batteries in "charging mode" for far longer and it may be that the charging mode of a battery, especially at incorrect temperatures, harms batteries.
- None of this likely matters to you or your car -- it is mostly an actuarial exercise for enterprises that mange large fleets of batteries who are trying to squeeze an extra 0.01% of reliability out of their fleets of millions of batteries.
As the saying goes "Those who know don’t talk. Those who talk don’t know."
What actually matters to you? Maybe money? I assume you pay for your electricity. The car has 2 sources of charging friction -- one is the transformers to take the 12a/120v input and bring it up to 400v the other is the battery heater. You always pay the conversion charge and pay for the heating charge in the winter. If you're you're spending 20-50% of your power just getting the battery ready to charge, not actually putting range into your battery, you're spending 20-50% more money charging your car than you need to. It gets even worse if you have time-of-use charges from your utility -- they will charge you more for power pulled out of the wall at peak times and less at low load times; having a 50a charging circuit lets you pump all your electricity into your car in the low cost window.
Another potential concern with charging on a standard 120 outlet is that you may not be charging on a dedicated circuit. The way an electric car interacts with the house is very different from any other appliance in a house; it will attempt to draw 80% of the maximum power from the circuit for hours at a time. Let's say that plug happens to be shared with a television or a stereo or a toaster or a water heater or some other appliance? If you run one or the other, everything's fine, but if you happen to be charging the car and make a pot of coffee, you may occasionally trip the breakers. This tends not to be the case with 240v circuits (in the USA) because those almost always are dedicated circuits between that one outlet and the breaker. Also, having lived in old houses my whole life, I would be somewhat skeptical of the reliability of a random outlet and I would want to assess the health of the in-wall wiring for a proposed EV charging setup. I would not bet on setups aren't actually charging a tesla thousands of hours a year on 60 year old outlets and wires using 40 year old circuit breakers...
Lastly -- a supercharger isn't really a good replacement for home charging -- according to the tesla-doesn't-advertise from tesla you may spend an hour once a week if you drive 200 miles in a week. In reality you'll have to charge 2-3 times and if you drive that little your battery will always be way below the peak charging threshold, so you'll be spending almost 2 hours to go from 20% to 90% and wasting the first part of the supercharging which should be super fast instead heating the battery. So you may be thinking you'll spend a relaxing hour at the supercharger once a week; in reality you'll be spending 3-6 hours per week if you're only supercharging, at least if you're supercharging an older S on a cold battery.
Supercharging is awesome for traveling long distances, but when you're driving long distances it is very likely your battery is already very close to the ideal supercharging temperatures.
The convenience of just plugging your car in and always having it warm and ready to go is pretty unbeatable.
