Of course the Model 3 has no battery heater. I DO charge using my Prius Plugin's Lvl 2 charger via the J-1772 adapter. What I see is, esp when I connect upon return from a trip the charge rate is generally 21-22 miles/hr if the car is cold it starts at a rate of 3 mi/hr and eventually goes up to maybe 11 or 15 mi/hr. That is, again, no battery heater.Well, I can address this part, and it's kind of in between. The "otherwise", which you seem to think is a rhetorical that doesn't happen, is exactly what happens in some circumstances, though. People who have connected to something like a low power J1772 station that was only supplying 30A have had it do no charging at all for sometimes a half hour or entire hour if it was far below freezing. It's doing nothing but run the battery heater with that 30A for quite a while first.
The way you stated this shows that you're thinking of it in a binary state:
0 = too cold = no charging
1 = warm enough = charge as fast as possible
It's not like that, because it's a gradual sliding scale of how many amps the battery can safely charge at based on temperature. There is a temperature point below which it is just too cold, and there can be no charging without damage. And the Tesla cars do prevent charging at those temperatures, unlike most other electric cars. But it can get up to a temperature where it can do some slow charging that is below the damage threshold, and that keeps rising to allow more amps as the temperature continues to get higher. That is illustrated in the progress of no regen versus limited regen versus full regen. That is what rate of charging it can allow based on temperature.
I think you could also make the argument your efficiency is better driving with a battery pack that is closer to optimal temperatures and you get full regenerative braking.
Yes, I understand there is heat scavenging.The Model 3 does have a battery heater function and it will be activated whenever the Battery Management System (BMS) determines it's beneficial to heat the batteries. It does this by passing current through the electric inverter and motor such that the motor heats up but does not apply a torque to the driveshaft. As the motor/inverter become warm, it pumps heat transfer fluid through them which carries the heat throughout the battery pack which warms it up.
Please don't quote my numbers someone here I'm sure knows them and will post. I think that the battery heat comes on and stays on no matter what until the battery reaches half regen which is about 58 degrees. (Range Mode Off) So timing your charges to end right before you leave with a warm battery does save energy. Battery heater is 6kw I believe.
That's good to know...thank you. So, by definition then, by having the Model 3 plugged in it will use wall voltage to keep the battery warm, If not plugged in it will use battery voltage to provide heat to keep the battery warm. Esp in the latter case this contributes to 'phantom' drain then.It goes beyond simple heat scavenging because it uses the components to CREATE the heat from battery electrical energy (or grid power if plugged in). While it does scavenge waste heat while driving, it also actively heats the battery while parked if the BMS determines it's beneficial to actively heat the battery.
Well, it could, but not necessarily that it will. It isn't going to just keep using energy to keep the battery warm all the time for no reason. It will certainly let it get below freezing without heating it if it's just sitting there off, and it's not trying to charge or anything. But if you plug it in to make it charge, it will have to heat up the battery some to get itself ready for charging.That's good to know...thank you. So, by definition then, by having the Model 3 plugged in it will use wall voltage to keep the battery warm, If not plugged in it will use battery voltage to provide heat to keep the battery warm. Esp in the latter case this contributes to 'phantom' drain then.
Understood. I didn't mean to imply it would. I've seen fluctuating morning battery levels. I've not correlated them to ambient temp. From watching the Ben Sullins show others have too. What I'm not clear anyone's done is correlate drain to external factors. Although I imagine some of these third party programs for iPhone/Android could as they have access to cabin temp. I've only had the car two months now and, in that time, there have been mild days and fridged days. I'd guess come mid Apr or so the behavior will become more predictable. I should look into Tesla API, after all, that's what I have done for 45+ years.It isn't going to just keep using energy to keep the battery warm all the time for no reason
