That's just unthinking spin.Apparently you didn't. The lesson was that all your generating sources need to be winterized.
"The much greater mass of Venus’ atmosphere translates into much greater adiabatic compression which, in turn, produces much higher surface temperatures. (On Earth, temperatures at Death Valley and the Dead Sea are hotter than elsewhere because of their negative elevation relative to sea level and the resulting increase in adiabatic compression.)"No. While compressing a gas heats it, on Venus it then radiates that heat into space and in a short time you have cold much less dense atmosphere in the absence of the greenhouse effect.
Here let me show you the physics so it’s harder for your to deny it.
Stefan-Boltzman Law
J* = sigma*T^4
Where J* is in watts/m^2
Sigma is a constant
And T is the temperature to the fourth
The average energy reaching the top of the Venusian atmosphere is 662w/m^2 but only 25% make through due its albedo (you can verify this yourself by simply looking at it. Venus is very bright because it reflects so much light due to the Sulfer dioxide in the upper atmosphere)
So
662 W/m^2 * .25 = 165.5W/m^2 at the surface.
Now we know the temperature at the surface is 735K
j* = sigma* 735^4
J* = 16500 W/m^2
16500 W/m^2 does not equal 165 W/m^2 so this system is not anywhere near equilibrium. Therefore, in the absence of the greenhouse effect which you deny CO2 is cable of, the hot side (the surface) is going to cool until is in equilibrium around 232K.
It sure seems like your adiabatic compression model doesn’t conform to known physics.
Your dog and pony show with the equation has nothing to do with adiabatic compression.
You don’t seem to understand thermal equilibrium. An atmosphere @ 730K cannot maintain its temperature when it’s only receiving 1% of the energy it’s losing. Without another source of energy source or an insulator to reduce the energy loss the temperature will decrease."The much greater mass of Venus’ atmosphere translates into much greater adiabatic compression which, in turn, produces much higher surface temperatures. (On Earth, temperatures at Death Valley and the Dead Sea are hotter than elsewhere because of their negative elevation relative to sea level and the resulting increase in adiabatic compression.)"
No no. He’s got a point. I went ahead and ran my compressor and the tank got warm. I also took a bottle of compressed air, used it and it got cold.What's the source of the compression? Death Valley is hot because there's more atmosphere to insulate it... has nothing to do with 'compression'. Compression causes heat not pressure. The SCUBA tank in my garage got hot when I filled it a week ago. Why is it now no hotter than the garage?
But... simple yes/no question. Does CO2 absorb and re-emit IR light in the same spectrum as Earth radiates into space?
The compressed can of gas is the surface of Venus.Totally explains why hot compressed freon does not cool down outside the home and why a compressed can of gas stays hot even after years of storage. I guess you're wondering how A/C works. LOL
Think of the compressed can of guess in your garage. What is the ambient environment around that compressed can of gas? Now, think of an air parcel (how meteorologists think) on the surface of Venus. What is the ambient environment around that air parcel? Put that in your pipe and smoke it a while.No no. He’s got a point. I went ahead and ran my compressor and the tank got warm. I also took a bottle of compressed air, used it and it got cold.
Thanks to @MitchP85D i know that compressed gases always maintain their temperature. So the compressor tank will stay hot forever and the compressed air can will stay cold.
I thought about using them to make infinite hot and cold drinks but now I’m thinking of putting a sterling engine between them and making a perpetual motion machine.
Because the compressed can of gas has an ambient environment that is colder than the can. On the surface of Venus, the atmosphere on the surface IS that compressed can of gas. An air parcel on the surface of Venus is surrounded by other air parcels of similar pressure and temperature. The surface air parcel cannot radiate heat to ambient air parcels because the ambient air parcels have the same temperature. So your compressed can in the garage idea is false.What's the source of the compression? Death Valley is hot because there's more atmosphere to insulate it... has nothing to do with 'compression'. Compression causes heat not pressure. The SCUBA tank in my garage got hot when I filled it a week ago. Why is it now no hotter than the garage?
A compressed can of gas that is in an environment that has the same temperature as the can will not lose heat.You really don't comprehend. LOL
Attention all of you global warming alarmists fixated on the Venus analogy:
"Unlike the Earth, however, Venus is always entirely covered with clouds. Neither the planet surface nor the lower atmosphere has any opportunity to radiate heat directly into space. Venus radiates heat directly into space only from its cloud-tops and upper atmosphere."
This obliterates the compressed can in a garage idea.
Venus
UPDATE: Initial version of this post used diatomic gas equation for the compression of CO2. Have now corrected this oversight, and find that...homeclimateanalysis.blogspot.com
Adiabatic compression rules.
An air parcel on the surface of Venus does not have insulation around it. Your "what if" is pointless.OK, so what happens if the can of air is compressed while the can is insulated? (Greenhouse gas effect).
Now, do you understand? Can't believe you were a weather forecaster. LOL
You didn't read this:OK, looks like you lost in 4D chess. You just made the care for global warming due to greenhouse gas effect. LOL
Lost power twice this week. The good news is they are supposed start work installing our generator today.Did they have to stop the wind turbine again? LOL
KPRC Click2Houston: Power outages reported across Houston area due to severe weather.
CenterPoint expects to have majority of remaining customer outages restored by the end of the day
Hundreds of thousands of customers are without power as Hurricane Nicholas rolls through the Houston area.www.click2houston.com
