Norbert
TSLA will win
You are clearly letting your bias interfere with your brain function. Maybe it's a steady diet of soy and lack of meat?
As to your point #1. In the past 150 years it has indeed been getting warmer. Is your brain not able to comprehend that the Earths history is longer than 150 years?
The problem is not that the next 4 Billion years will be like the last 4 Billion years, but that the next 150 years will be what the last 150 years indicate.
As to point #2, the Co2 inputs I referenced are clearly the human inputs to the atmosphere. But your steady diet of Beyond meat has left you low on cholesterol and therefore unable to understand even the most basic of concepts.
You mean CO2 emission? There is also reduced CO2 absorption. Those are names by which I know those things.
There is not much to disagree with: The effects of additional CO2 on temperature, as well as the significant effect of small-sounding temperature differences in the global average. In the opposite direction, for example, the Ice Age was only about 7 degrees Celsius lower.
Unless you consider the distortions from the oil and mining industries as equally valid information, which it isn't.
