Yes. These can be set at any height and I'd find a custom tuning shop for the install. It's straight forward but they'll know how to adjust it better.i like mine higher is that possible with these shocks?
Any update after almost a year with your suspension?
Hi everyone. After having it installed for a couple of months, I just couldn't get the ride as smooth as I wanted it. I then realized that the springs that came with the setup was much stiffer than it I would've preferred so I bought a new set of softer springs. Before I had a chance to install the new springs, the wife made me remove the setup so I'm back on stocks. Been meaning to go thr airbag route but haven't had the chance yet. Basically, I still have the set which is brand new with a new set of softer springs if anyone wants to buy them at a discount. Let me know if you have any other questions.
Now, I just messaged the company since I left it default to whatever and I have no idea what the default is. I also told them my driving style, preference, family hauler on weekends, etc. and hopefully they can decide on the best spring rate for my situation. Thank you for pointing out the spring rate.Hi,
That's tough. From my experience, coilovers in general are much stiffer than your OE ride. I tried dialing the compression all the way up, softest setting and it was still harsh, like I can feel every imperfection on the road. Freeways were not any better, like the car bounced around. Keep in mind, it may have been the incorrect spring rate. That's why I bought a new set of springs. Do you know what rate your coilovers will come with? If you're looking to keep your car at the same height, there are imitation bilsteins on ebay for $900. I have no experience with these so can't comment.
Yes, I left it (spring rate) to "default" and I didn't pick the LOW version either.I see the custom spring rate options are available -- did you pass the stock rate on to Scales? If so, I'll be very interested to see what they are like. I made it through my state inspection last week with no issues on the stock struts, but I feel like every year at this point is a hope and prayer!
I'm actually researching procuring adjustable camber/toe (rear) for my MS so that the alignment will go smooth after installing the coilovers. Some of the aftermarket kits (adj camber/toe) are almost the same as the Scales suspension !!!Good luck. I'm def no expert so I can't argue with their statement. I hope it works out for you and I really wanted to love mine bc the adjustability is awesome. I don't think mine had the bottom out issue mentioned, it just felt like there was no give which was great on turns but not so great with everyday driving.
