Cost Comparison EVs vs ICE
wdolson
7,418
9,916
Clark Co, WA
I was thinking about the cost per KWh and per mile between gasoline and BEVs. Gasoline has between 32 and 34 KWh per gallon, which makes it one of the densest energy fuels there is. The EPA uses 33.7 KWh per gallon for MPG equivalent calculations, so I used that in my calculations.
In energy cost per KWh, gasoline is currently cheaper than electricity, even here in Washington State where it's only $0.08/KWh. Because electric vehicles are so much more efficient than ICE, the cost per mile for the least efficient EV at $0.16/KWh is cheaper per mile than even a 50 MPG gasoline car at $2.00 a gallon.
In places where the cost of electricity is much higher like Hawaii, EVs aren't as economical when gasoline is cheap. Of course if you can put in solar in a place where it's expensive and your only cost of electricity is the original expense for the system.
Anyway, I thought some people might find the chart interesting.
calisnow
Banned
Oct 11, 2014
2,867
4,650
Los Angeles
Obviously a lot depends on which ICE you are comparing to and how much you drive. If your ICE cars were like mine - 14-15 mpg and requiring 91 octane in a high-price gas state like CA, and you drive 30,000 miles per year - even an $80,000 Tesla is a money saving device. Hypothesizing a $3 per gallon long-term gas price, and my current rate of $0.11 / kwhr, I calculate that over an 8 year ownership period my Tesla will save just over $50,000 in fuel and oil changes compared to the ICE it replaced.
Reactions: newtman
wdolson
7,418
9,916
Clark Co, WA
Yes, different people will get different break even points, but by looking at the cost per mile it gives you an idea if a BEV is actually cheaper or not to run. In places where electricity is very expensive, when gas prices are low, the ICE might be cheaper. For example if you have a car that gets better than 25 MPG, if gas prices are $2.50 a gallon, and you live with electricity rates at $.30/KWh, it's cheaper to drive the ICE.
If you have access to cheap electricity like Washington State, it's always cheaper to drive an EV unless gas prices plunged to levels we haven't seen in decades. Of course if you have a solar array, it's always cheaper to have an EV too.
I don't even want to look at the break even point for cost of ownership for me. I work at home, so it's probably something like 50 years. From that perspective, this is a very dumb purchase.
dhrivnak
4,389
3,516
NE Tennessee
Anyway, I thought some people might find the chart interesting.View attachment 175729
I think you are leaving out the very important efficiency part of the equation. Using the 33.7 conversion an electric car gets 89 to 120 MPGe. An ICE is lucky to get over 40 MPG. An EV can run over 80% wall to wheel efficiency where an ICE is about 25%
wdolson
7,418
9,916
Clark Co, WA
If you look at the chart, the whole thing is about efficiency. A 50 MPG car is 0.66 KWh/Mi and the more inefficient BEVs are under 0.40 KWh/Mi. Many cars are over 1 KWh/Mi.
jerry33
Mar 8, 2012
19,516
21,709
Texas
And that assumes the 50 mpg car actually gets 50 mpg. The real issue is: Is saving money the only reason you're purchasing? Energy cost is just the icing on the cake.
Reactions: newtman
cpa
3,005
3,708
Central Valley
Missing from many discussions is the time factor involved with the routine servicing and repair of ICE vehicles.
When I take our remaining ICE in for service, I need to arrange for a ride home, or wait, or walk home (it is only 4 miles, so no big.) Then, reverse when the car is ready. I work from home like wdolson. But it can be worse for someone who works for an employer. He/she arrives to work late, may have to arrange for a ride home after work and another ride to work the next day, and then a ride to the garage to retrieve their car.
I do not know how to put a dollar value on this sort of intangible benefit (including not spending 10 minutes at refueling stations when needed.)
But to me this alone is worth quite a bit!
Reactions: EVie'sDad
newtman
132
116
San Francisco
Hmm...seems like most Tesla owners have had to take their car into the service center a number of times, so not sure there's much benefit here. My last car, a ford, was only in the shop 3 times in 3 years, all for recalls or yearly service.
wdolson
7,418
9,916
Clark Co, WA
From reading the various threads here, it looks like Tesla is getting to a point with the Model S where the inherent maintenance advantages are starting to become apparent. The early Ss and the X still have/had enough problems that many owners have spent more time with their car in the shop than they would have with an ICE.
The not having to stop at gas stations thing is a big plus for me. We get brutal, cold winds here periodically in the winter. Refueling the car when the wind is blowing is downright painful.
jerry33
Mar 8, 2012
19,516
21,709
Texas
FWIW, I've spent about the same amount of time over the past three years having service on the Model S as I've had with any other car. I suspect that folks who've had experiences similar to mine don't post and probably aren't even in the forum.
Reactions: newtman
kort677
Banned
Sep 17, 2015
4,801
2,241
florida.
a 50 mpg ice car? does that exist? even the most frugal diesel only get's mid 40's mpg. trying to compare an econo box ice to a car like the model s, really?
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
The only one I know of is the Toyota Prius.
I find these calculations simplest as pennies per mile.
At $2/gallon and a 50 mpg car it works out to 200/50 = 4 cents per mile
If a kWh costs 16 cents then the breakeven point for an eV is 4 miles per kWh. Or,
If the car gets 3 miles per kWh then the breakeven point is 12 cents per kWh
And so on...
The tricky part is using an Apples to Apples comparison. Simplest is EPA to EPA. For EVs the MPGe (combined) can be multiplied by 3 and then divided by 100 for a fairly accurate miles per kWh number.
jerry33
Mar 8, 2012
19,516
21,709
Texas
My lifetime average over 146K miles of 2004 Prius driving was 60 mpg. The last year was 69 mpg over 16K miles.
Reactions: SageBrush
calisnow
Banned
Oct 11, 2014
2,867
4,650
Los Angeles
FWIW my 2016 70D has had no issues so far - 7000 miles and three months of ownership. Perhaps finally now that Tesla is in the 5th year of production on the S, the issues have been ironed out.
Reactions: newtman
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
Nice! I could hit 70 mpg over a tank or three, but the winter or wife would stop the streak.
What fuel economy are you hoping for in the Model3 ? I'll be OK with 235 Wh/mile for most of my miles commuting to work since I plan to drive faster than present, but I think that 200 Wh/mile will be possible with care.
Jeff N
2,271
2,902
Of course, it's not fully comparable to a Model S but it's not an econo box and it has reasonable performance with very good gas mpg:
2016 Chevrolet Malibu Hybrid
182 HP, 0-60 mph 7.8s (7.4s MotorTrend)
EPA 47 mpg city, 46 mpg highway
$27,770 ($28,645 including destination charge)
CO2/mile: 236g, TM S75D 190g US (280g Michigan)
jerry33
Mar 8, 2012
19,516
21,709
Texas
My Model S has achieved 248 Wh/mi over 70K miles (was 247 before the last bad wind both ways trip last week, will take a couple of weeks to get it back down). I was planning to order a Model 3, but the other driver totaled the Prius, so I got a Leaf for her. Note that it cost about as much as a fully loaded but not performance Model 3. I so hate buying from dealers.
