Somehow I don't think the author was contemplating a 20kW HPC. Good read, though -- it'd be great not to have the parasitic load of all those AC/DC converters for all of our gadgets and modern lightbulbs.
I don't know there is a lot glossed over in there.
All of the big power draws in your house are probably AC induction motors (AC, Refridge, Blowers/Fans) These run off AC power. It would be stupid to take DC->AC losses on the largest power draws in your house to save on the rest.
The other big power draws are heating elements. Sure they work with either current, so they are a wash. Besides any conversion losses wouldn't be net losses because they produce heat.
Line losses are lower with higher voltage. There is a reason why home power is 100VAC and higher. The line losses below 100V are just to great. This won't change with DC.
DC->DC voltage change equipment is much more complicated and expensive than AC->AC. This is why AC won the current wars. And I believe that DC->DC conversions are also less efficient. So going AC->DC might not be that much worse than going DC->DC stepdown. I really don't know much about DC->DC step-up and step-down. Especially if you consider greater line losses for a 24VDC system.
And this nonsense about your AC and other induction motors running more efficiently on a VFD (Inverter). NO. First refrideration cycles don't need modulated speed. They just cycle. The motor is always run at its most efficient point. Besides a VFD is a conversion device. You would have DC->AC conversion losses. VFDs (Inverter) are common going AC->DC->AC in industry but they are expensive, and if they would work in the home the extra AC->DC line losses wouldn't be a factor. Same with induction charging. That is AC. I can't fathom a scenario where DC supply would be more efficient than AC supply in an induction charging application.
I really like DC. It is way easier when taking electronics classes. But really this is just a guy looking at his phone, iPad, laptop, and other battery/usb devices thinking it would be great if they didn't require an AC->DC conversion. And he is right. But it is stupid to drop AC power. Truth is AC works better and will for a very long time.
Add on to that fact you can't use any high power devices on your home wireing. No vacuum. No Toaster. No Microwave. No slow cooker. No blender. No kitchen-aid. No Gaming PC. Hell even laptops draw 100W, which would overload his suggested 24VDC 4.1A circuit.
None of that really matters this is why AC will be prevalent for a very long time:
AC->AC is easy and cheap
AC->DC is easy and cheap
DC->AC is complex and expensive
DC->DC is complex and expensive
