Older cars would need to cycle the big dc to dc converter on and off, and power the LARGE main contactor. There is a separate smaller contactor, along with a lower power "smaller" dc to dc converter. For starters, you are not cycling the 12v battery as much. To reduce wear on the main contactor, the MCU and other electronics would draw from the 12v, when the 12v got low enough, main contactor would need to be activated, and the main dc to dc converter would recharge the 12v battery. Rinse and Repeat. This puts more cycles on the 12v battery, as well as more open & close cycles on the main contactor. The MCU would also need to go into a deep sleep to prevent running the 12v down as much. This all puts more cycles and wear on the 12v battery, main contactor, and the main dc to dc converter. You also get those long load times for the older Model S's to connect to the app. That is why there are more power options in the older Model S cars with MCU1 to allow the car to do a basic level sleep, sleep with cellular connectivity on so the app connects faster but the car uses more standby power, or deep sleep which takes much longer for the app to connect, puts the car into deep sleep, also requiring anywhere from 10-60 seconds for the car to fully power up when you get in.
By a separate smaller set of components, to keep the 12v topped off, and directly power the MCU and necessary electronics, with a constant power feed from the HV battery, things last longer. Less 12v battery cycles, main contactor not cycling on and off, and expensive DC to DC converter not being used as much.
