Jughead135
I simply removed the lowest metal clip from the tab on each fender liner making it easy to do with fingers alone by pulling the bottom of the liner toward the back of the car and then putting your fingers in the gap between the liner and the fender and pulling the liner toward the back of the car again releasing the next clip up.
Thanks for the info! A year & a half later, I still haven't found an acceptable solution to this--I've just been accepting the risk.
Can you expand on the quoted part, please? I'm not clear on where/how/what it is you removed. What does this metal clip hold, that it has no effect to remove it (aside from allowing easier access)?
I already carry a jump pack like the one you cite. Won't do me much good if I can't get into the frunk, though...!
