This isn't about the wall connector, so irrelevant.Long answer - Reasons for wall connector:
A. What would make you say it "isn't readily available"? It goes in and out of stock just like many other things do on Tesla's shop, with its precarious supply chain.Corded mobile connector, I believe, isn't readily available. The UMC is perfectly fine.
So it costs the same as a real wall connector but has more limitations. I'll pass.I just wanted to let you know that the corded mobile connector is expensive at $520. A much better purchase would be the corded 14-50 wall charger that appears intermittently at Tesla site and costs $500. I just got one and it came home 2 days ago. It is massive and built like a tank compared to the puny mobile corded charger.
In fact, it is the same size ( and probably the same) as the regular wall charger that you need an electrician to install. I have that too and both main wall elements look identical. It is just that the corded one has a 14-50 attached securely with a cord and because of this it is limited to 40A. I am pretty sure if you rewire it and remove the cord it can go to 80A, like a regular WC. But the advantage of having the cord is that you have a wall plate with a couple of screws to attach and then attach the WC to that face plate, and plug the cord into the 14-50 outlet- Voila.
A regular wall connector can be removed just about as easily.And when you move it can be removed within 10 minutes and taken to new location. A much better buy if you want a portable solution that you intend to keep in your garage
Agreed.A regular wall connector can be removed just about as easily.
Yeah, You'll spend more time dismounting it from the wall and patching the holes in the drywall than you will dealing with the wires.Agreed.
I watched the electrician mount my HPWC, and it really is easy to mount/dismount. Five minute job, tops.
I ordered my M3 on Monday. I don't have a commute only 4 miles each way so I'm thinking I will only need to charge about 3 times a week? I was just going to use the charger that comes with the car and buy the 14-50 adapter. I have an electrician coming to put the 14-50 outlet on the side of my house where my driveway is.( I have a detached garage that is just used for storage) . I don't need to buy the corded charger, do I?
if I were to get the Gen 2 14-50 adapter with the Gen 2 Mobile Connector, wouldn't I just be saving money and getting additional flexibility for road trips?
If NEMA 14-50 is inside the house, no problem.
If the NEMA is installed outside ( with cover box) then you may need to plug and unplug each time and that can cause issues with loosening of wires and heating and melting of receptacle. Especially if you put in a cheap one.
Another option for outside would be weatherproof enclosure that could fit the outlet and UMC, but I would just install a wall connector instead. I'm all for saving a buck when I can, but no sense being so cheap that you put in something kludgy.Thanks for the info, I will have to now re-think this.
@darth_vad3r correctly points out that 120v would work for your commute, but it doesn't solve the lack of weather proofing of the UMC or the plug and unplug problem. It also doesn't address that fact that you might drive a lot more on the weekends and might like to be able to charge overnight in that situation. Personally, I'm a fan of installing a solid charging solution and using it every night whether you "need" to plug in or not. For your short commute, set the charge level to 70-80% and just plug in every night.
