I've been trying to look for as many pictures of the Model 3 as I can to confirm whether the turbine wheels will come as directional wheels or not. From what I can tell looking at the Silver car, they are not directional. Meaning all 4 wheels look the same.
Doing a search, I've run into a few posts on the Model S sub forum, where this has been discusses at length, and it seems that even on a much more expensive car (S), and at a cost of $4,500.00 for them, the turbine wheels for the S are not directional.
Copied from a post: "Directional wheels would have right side and left side wheels so the blades point the same direction when viewing the car from either side. Currently the blades point one direction on the right and the other direction on the left."
I would assume that's the case for the Model 3, and the included pictures of the left rear wheel and right rear wheel show it's the same design from a blade pointing direction. However, I did see a picture of a shiny black Model 3 which shows the right side of the car with the "correct" directional wheel. But since we know of no shiny black Model 3 (only the matte Black one), it could be a mirrored photoshop.
Having 4 of the same wheels instead of 2 lefts and 2 right directional wheels would drive my OCD a bit nuts.
Anyone have any thoughts or comments? Would not having directional wheel drive anyone else crazy? I would think it would play on the aerodynamics of the wind swirling around the wheels/rotors/brakes. But sadly most cars out there only have 1 wheel design and hence 4 of the same wheels regardless if the pattern is reversed on one side.
Thanks,
Cintoman
Thanks,
Cintoman
