89% round-trip efficiency is surprising (even lower than PW2), I was hoping it would be higher given all the talk about DC-coupling.
DC coupling only impacts solar to battery. Grid to battery to grid is unchanged.
89% could be due to slighly higher cell equivalent resistance or various other factors. 94.9% one way vs 94.3% (not that charge and discharge are necessarily equal).
That's a function of the ratio between batteries and non batteries in the unit.Is it just me, or does it seem there is a lot of empty space inside?
dhanson865's photo shows these lights and on my middle pw the bluer led in the middle does not light up.So, just had 3x Powerwall 3 installed yesterday with backup switch and solor, and I think one might not be working correctly.
Installers said I was one of the first to get the pw3. I am not an employee, just placed an order for solar and Powerwall 2 months ago and this is what they gave me in Austin.
2 of them are showing on my WiFi and the third one stopped after about 1-2 hours. None of the info online about connecting directly to a pw directly to get info works. When opening 192.168.9.1, I bypass the cert error then just get error 404.
I had a very short burst of generation after they turned them on and the batteries charged from 19-32% before the sun went down. Most of that was done shortly after turn on then the generation dropped drastically with complete sun and temp of high 70s.
Apparently these are on right away and all the PTO is done remotely (although there is a button in the app to turn on). This means that for everything but exporting I should be good to go.
Testing off grid mode last night with 32% I set my reserve to 22% and using 1-1.5kw of power said my estimated time was 2-3 hours which seems low.
The middle power wall seems to make a click sound like a relay turning on or off now and then and sometimes flashes red.
You can see a green light on 1 and 3 at night and something very faint on 2 but looks like a different led that just happens to be shining through partly.
I could tell the installers kept going back to pw2 but I am. It sure why. With the low run time estimate I am wondering if pw2 just is not actually charging or booting correctly.
There is no reboot or reset switch, there is no documentation and nothing on the interwebs about pw3. And of course today is cloudy but I am only generating .7-1kw of energy with a 13.5kw system, which seems low. Each pw has 11 panels with number 3 having a string of 9 and a string of 2.
If I push the off switch for 2 and 3 the generation and Powerwall percentage does not change.
So besides possible issue with number 2, when I go to off grid mode lights flicker or flash constantly running on the batteries. Does not seem to happen if on grid and using batteries.
I did charge the pw to 50% last night using the grid and tried off grid this morning with same result and lower than expected remaining time.
Will let you know more and I will be reaching out to support but just thought I would share. New heart here.
Jerry
Thanks. i went through the setup but am not able to get in. My main PW is 192.168.200.51 however, it does not look like one according to pyPowerwall. None of the instructions for any previous powerwall work for me to browse to it in a web browser either.I'd suggest setting up Powerwall Dashboard, where you can get individual stats on each powerwall.
GitHub - jasonacox/Powerwall-Dashboard: Grafana Monitoring Dashboard for Tesla Solar and Powerwall Systems
Grafana Monitoring Dashboard for Tesla Solar and Powerwall Systems - jasonacox/Powerwall-Dashboardgithub.com
You will see good details on each unit, along with charge and errors (depending on how much your 2nd PW might be failing).
Jerry
PTO is typically done after inspection by the utility. Even though PTO stands for 'permission to operate' in my installation Tesla made the system operational before PTO. PTO was required before exporting energy to the grid (think of PTO as PTE, permission to export).You didn’t have to wait for an inspection before PTO? I’m near Austin, and install date is in Dec 4!
In the app I have told it to connect to my wifi and that is the IP assigned to it. With multiple PW3, one is the primary and the others listen to it, apparently, although initially all three were connected to my wifi but the middle one stopped connecting soon after. I then used the app to change from my g=uest network to my regular network and only the primary changed over, the third one is still on my guest network.I'd suggest trying the TEG wifi network as well if it's available. I think the password should be written on the sticker inside the enclosure. You'd connect to https://192.168.91.1 (assuming they haven't changed that).
I'm also curious, how do you know the PW3 is on 192.168.200.51 if it's not accessible? And what happens if you try to load https://192.168.200.51 in your browser?
Yep, same with me, I am unable to export to grid but have "full service". Although i honestly think only 1 of the 3 is working based on charge and discharge amounts on the PW and solar production. Was just installed on Friday so hopefully I can get support tomorrow.PTO is typically done after inspection by the utility. Even though PTO stands for 'permission to operate' in my installation Tesla made the system operational before PTO. PTO was required before exporting energy to the grid (think of PTO as PTE, permission to export).
