Coming once again to this forum for help as Tesla is giving me the runaround and what I think are some BS lines.
I ordered 3 Powerwalls with a 9.315 kW solar array. Tesla is saying I can only have *ONE* Powerwall 3 bc my utility has a limit of 20 kW AC (see snippet below); PW3 has 11.5 kW of power output.
First, I thought 11.5 kW was the *max* power and it could be "set" or "turned down" by wiring/breaker specific to your install.
Second, ironically enough I was told "PW3 doesn't exist" when I ordered and now they aren't even bringing up an option for PW+/2 for me which has a lower power rating. 1 PW+ and 2 PW2's would be under this alleged 20 kW limit I believe.
Third, direct from the utility (Duke Energy) website the application you have to fill out for interconnection is worded as a "certified inverter-based generating facility no larger than 20 kW." Well my solar array is 9.315 kW so it will likely have a 7.6 kW inverter, far less than 20 kW as noted below. I am not disputing there is a 20 kW solar array limit, but I don't see how battery backup has anything to do with that. The battery power output is to run your house loads; what does that have to do with my utility?
Fourth, I called the "Duke Renewables" line which is just a customer service line for solar basically and they said what I said above. The 20 kW limit is related to your "solar generating facility" and the batteries don't matter.
What I am missing here everyone? Am I crazy?
Link directly to Duke:
From Tesla:
From Duke:
Interconnection for Smaller Capacity - Duke Energy
Interconnection process for business projects less than or equal to 20 kW. To submit a request, learn more at Duke Energy.
www.duke-energy.com
From Tesla:
From Duke:
