Do Autopilot Repeaters fit in non AP hole?
Discussion in 'Model S' started by richrootes, Apr 20, 2019.
  1. richrootes
    richrootes Member
    North Vancouver
    After seeing Sentry Mode catch some quite appalling door dingers in action, I’m wondering how much it would cost to retrofit the later AP side repeaters
    I’m not interested in Autopilot, but somehow wiring up the cameras to a recording device inside the car would sure give me more confidence when using public car parks - where inevitably, wherever you park, you get some dick in a Monster Truck in the space next to you
    Anyone tried this?
  2. JerryEVall
    JerryEVall Member
    Also wondering about this. Hopefully there is a way to retrofit as I am also thinking sentry mode but not autopilot.
  3. glide
    glide Member
    Why wouldn’t you get a 4-channel dash cam instead?
    That’s going to be substantially less expensive, time consuming, and will not require hacking the software.
  4. richrootes
    richrootes Member
    North Vancouver
    Are there dashcams that can see along each side of your car - like the repeater cameras do?
  5. IchDochNicht
    IchDochNicht Member
    Bay Area, CA
    I asked a very similar question recently in this thread:
    Aftermarket Sentry possible for pre-AP2 cars?
    I see the fender cameras sell on eBay for about $180/each. They may work as a visual deterrent, but we learned it is cheaper and simpler to use other solutions.
  6. richrootes
    richrootes Member
    North Vancouver
    Thanks - the Waylens solution looks good, but it won’t spot door dingers, whom should be corrected by having their heads slammed repeatedly in the style of Lock Stock and Two Smoking Barrels....
  7. glide
    glide Member
    Yes. You just point them to the sides rather than the front/back.
    Yes. Try BlackVue. You can position the camera front/back and left/right.
  8. richrootes
    richrootes Member
    North Vancouver
    Thanks
    Until then though......
